diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   KEF B169 T/S parameters (http://www.diyaudio.com/forums/parts/227875-kef-b169-parameters.html)
deanxxx 15th January 2013 01:38 PM
I have two very nice KEF B169 (SP1432) 6*9 woofers that I'd like to mount into a TL line but can't the find the T/S parameter info anywhere on the web!
Any help appreciated ;-)
Dean.
Zen Mod 15th January 2013 01:40 PM
169 or 139 ?
look for Planet 10's web pages
deanxxx 15th January 2013 02:21 PM
Originally Posted by Zen Mod (http://www.diyaudio.com/forums/parts/227875-kef-b169-parameters-post3326965.html#post3326965)
169 or 139 ?
169.
I had a look at planet 10, can see anything relating to B169s :(
cheers,
deanxxx 16th January 2013 08:07 AM
UPDATE
someone from another forum said:
based on measurements:
Qts = 0.42
Vas = 30 L
Fs = 38 Hz
after approx 24 Hrs run-in.
Albertb 4th November 2013 02:46 AM
I know this is too late to help Dean but it may serve as useful to others looking for this info. This data was supplied by KEF Technical Support Services when I got my hands on a pair of these great drivers. They were extremely open and helpful, nice to see in today's very closed world!
B169 - SP1432 parameters
Re=5.5 ohms
Fs=50Hz
Qm=4.1
Qe=0.72
Qt=0.61
Bl=8.9
Mms=33.4g;
Hope this helps.
deanxxx 4th November 2013 03:44 AM
Originally Posted by Albertb (http://www.diyaudio.com/forums/parts/227875-kef-b169-parameters-post3690498.html#post3690498)
thanx matey ;-)
I got a slightly different value for Qts at 0.42 (the bloke I bought the drivers from measured a few parameters) but at least I can do some rough modelling now. I havn't built any speakers as yet but when I get to it I was thinking of buying one of those speaker measuring kits to get the the actual T/S values.
Cheers.
Albertb 4th November 2013 01:04 PM
Hey Dean, so my rumour of your demise has been greatly exaggerated! ;) I had thought that Jan to Nov would have been too long for the info to be of use to you. Glad it's still helpful. You must be like me, the plan takes quite a while, the build up to doing something with it takes much longer, then the build is a frantic short period of whirlwinds and dust before the gems appear.
One intriguing bit of background I have just picked up on is that KEF were pretty notorious for passing out of spec drivers on to the DIY market. If you can make any sensible measurements to check these figures for your drivers it would be useful to hear how close KEF's figures really are. I don't know if this would apply to the B169 as I believe KEF had stopped supplying DIY bits by the time they appeared. Ours could be questionable back door models though. Best idea is to measure basic parameters before the build and evaluate carefully afterwards I guess.
Good luck with the project.
deanxxx 4th November 2013 03:08 PM
Originally Posted by Albertb (http://www.diyaudio.com/forums/parts/227875-kef-b169-parameters-post3690873.html#post3690873)
Cheers Albertb. You pretty much described my working methods ;) Interesting info about KEF. So I will defo measure the drivers. Not sure which kit to buy or make. The Dayton Audio DATS looks affordable but not sure if it is very accurate.
Resources saved on this page: MySQL 18.75%
