| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi. Is anyone knows where can buy XLR 4pin to 3 pin male adapters? Thanks a lor.
#2 |
Since there is no standard on this type of connection, you will have to make your own or have someone build it for you. An XLR connector is a couple of bucks. Use 22AWG mic cable like Belden 8451 or a more sturdy rubber jacketed version of it- I forget the number. It's on Belden's site.
What are you trying to interface?
"Most people just say what they know, the wise ones know just what to say." |
#3 |
My MBL 6010 preamp useing the 4pin XLR. crazy..... I cant use XLR connect my poweramp.
#4 |
The XLR 4 is standard in the broadcast industry for 12 VDC power supply connections. Be careful if your equipment is likely to ever be used in any mixed environments where you are not 100% sure of the other interfaces.
The connectors, Neutrik or otherwise can be sourced form lots of places like Parts Express and Markertek. Like Thunau was saying, you are likely going to have to engineer the adapter yourself going pin for pin from each connector to the next. Are there separate XLR-4 for the left and right channel, or does the pre-amp use one connection for both left and right channels? |
| CEE 7 French Plug Bar - Male Earth Pin | jonclancy | Everything Else | 4 | 11th June 2007 07:50 AM |
| WTB: BNC male connectors | Jimmy154 | Swap Meet | 0 | 9th November 2005 03:11 PM |
| Why are XLR outputs male, and inputs female? | Bricolo | Parts | 5 | 30th August 2004 01:43 AM |
| male 5 pin DIN plug | gfspac | Parts | 0 | 24th March 2004 04:54 PM |
| question about male rca | sma | Parts | 5 | 18th January 2004 11:34 AM |
| Page generated in 0.07480 seconds (74.01% PHP - 25.99% MySQL) with 10 queries |
