Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th November 2003, 06:20 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default Aren't gold plated connectors supposed to be inoxidable?
That's how my "High-End" (according to the local store) RCA connectors look like.
I manipulated them with my fingers, and didn't touch them for 2 weeks
Now I can see my fingerprints on them, looks like oxidation. And it don't get away with acetone or alchool
Could this be "false' gold??
Old 13th November 2003, 06:33 PM   #2
Steve Eddy's Avatar
Default Re: Aren't gold plated connectors supposed to be inoxidable?
Could be. Real gold shouldn't do that. I suppose it's possible that there's no gold on it at all, just polished brass which looks strikingly similar to gold but when handled, can tarnish just as you show in the photograph.
Try dissolving a couple tablespoons of salt in about half a cup of vinegar and see if that removes the fingerprint.
se
Old 13th November 2003, 06:36 PM   #3
SY's Avatar
It could also be that what you've got is very thin gold flashing, rather than a nice, hard electroplate.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 13th November 2003, 06:37 PM   #4
Bricolo's Avatar
thanks for the tip
should I put the entire connector in this solution, or simply put a little of it on a coton?
Old 13th November 2003, 06:57 PM   #5
lux0 is offline lux0  Canada
It's probably a cadmium chromate dip....modern fools gold.
Old 13th November 2003, 07:06 PM   #6
Steve Eddy's Avatar
thanks for the tip
Either way. Whichever one you do, just be sure to rinse it off well with some water afterward. Otherwise things will start turning green.
se
Old 13th November 2003, 07:11 PM   #7
Steve Eddy's Avatar
Yeah, a gold flash directly on the brass with no nickel barrier plating could give similar results I suppose. If that's the case, they're beyond cheap as even the cheap gold flashed stuff typically has a nickel barrier plating. And the "direct" gold plated stuff usually uses a gold/cobalt "hard gold" alloy.
se
Old 13th November 2003, 07:14 PM   #8
tool49 is offline tool49  Canada
tool49's Avatar
There is a commercial product named GoldShine that does miracle to these connectors. It is designed to clean fingerprints from rings and earrings.
On a side note, I often used a product called Silvario to thoroughly clean and add a thin coat of conductive silver to the connectors. The only problem with this product is that you need to reapply a coat every time you mess with the connection.
Both products should be available in your local jewelery store.
Hope this help.
Sébastien
Old 15th November 2003, 08:52 AM   #9
Bricolo's Avatar
Thanks Steeve!
I tryed the vinegar+salt. It's better now.
The fingerprints aren't totally gone, but it's far better
Old 15th November 2003, 04:36 PM   #10
Steve Eddy's Avatar
Thanks Steeve!
Great! It works well on copper too. I usually use it for cleaning the bottoms of my saucepans.
se
Direct Gold plated PCB reMC Digital Source 0 9th April 2008 03:32 PM
Gold Plated BNC Hardware fmak Digital Source 129 26th March 2005 05:25 PM
Aren't 4th order LR crossovers supposed to pass squarewaves? Bricolo Multi-Way 19 28th November 2004 03:47 PM
Gold plated jacks to... johnferrier Everything Else 1 21st December 2003 05:09 AM
Page generated in 0.10987 seconds (79.50% PHP - 20.50% MySQL) with 11 queries
