| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#21 | |
I modelled quickly - so could be mistaken the lumped element and distributed element of a cable - from Hifi News - a UK publication. I assumed 3metres - stated parameters in Hifi News are 0.36uH/m, 4.6mOhms/metre, 295pF/m. I ran the lumped element into 8ohms resistance, and distributed element also into 8ohms. B2Spice allow you to implement the graph as a formula. For the lumped element i used the vdB probe - which is always taken to 0volts. For the distributed element i used dB[magnitude(voltage across 8ohms)] which has slightly different results. Lumped element rolls off at 18dB/octave Distributed element rolls off at 12dB/octave. The lumped element as a clean roll off, where as the distributed element has two resonant peaks before rolling off - both simulated to 100MHz. So - i may have my simulation wrong as it was completed is haste, but i do believe that lumped element is different to distributed element. Regards, Shadders. |
#22 | |
I think it's fair to say we get a similar shaped curves for the two models. Out of interest, what did you get for -1dB point? Last edited by deanxxx; 2nd January 2013 at 10:27 PM. |
#23 | |
I'm no expert by any means so I'm not all that sure I'm doing anything useful or that relates to the real world. I hope to actually compare the EWB sims with real-world measurements at some point. |
#24 | |
At the -1dB point, i obtain 600kHz for the distributed response and 700kHz approx for the lumped response. I think the 1dB at 23kHz may mean you may be using too many elements - or the cable length is quite long ? Regards, Shadders. |
#25 | |
295pF/m seems a bit high Do you know what gauge and spacing were they using?
Doug We are all learning...we can all help |
#26 | |
I may be wrong - not sure regarding the simulation of lumped and how i measured the signal of interest - across the 8ohm load. As you have stated the differences are at the higher frequencies beyond the hearing capability of people. A frequency response will only indicate the steady state levels at the speaker terminals - but a transient response may be more revealing. I don't have golden ears - so i would not know if there are differences between cables - but too many people report that there is - this is in publications, not just forums - so scientific analysis must be pursued to resolve where the percieved differences occur. Regards, Shadders. |
#27 | |
This was a Highly Commended cable in Hifi News - states as above the specifications - other have lower 105pF, down to 30pF and up to 925pF. So i used one that was recommended and had high capacitance and slightly below average inductance. Regards, Shadders. |
#28 |
multiple RLC sections are still called lumped element approximations - Spice also has a "continuous" transmission line model
some like to use just a single RLC section - may often be good enough for audio - but multi section RLC lumped TL can approach the continuous model in accuracy at increasingly higher frequency as the number of sections/cable length increase and, as usual, audio frequency "transients" don't stress the accuracy of even single section RLC cable models for domestic <10m lengths compared to the continuous TL models - as long as both are ignoring skin/proximity effect |
#29 |
About ten years ago, Cyril Bateman did some cable modeling and testing. It quickly got complicated.
http://www.waynekirkwood.com/Images/...nteraction.pdf http://www.waynekirkwood.com/Images/...ing_Cables.pdf
Kevin |
#30 |
Continuous models and lumped are identical as long as each lump is less the 10% of the electrical wavelength. It is unusual for either model to take into account changes of resistance due to skin depth or capacitance with dielectric constant over frequency.
| Old power cables make good audio cables? | paean | Parts | 9 | 2nd November 2010 08:21 AM |
| NAGYS AUDIO Best Audio Cables in the World!!! Guaranteed!!! | NagysAudio | Vendor's Bazaar | 0 | 25th August 2010 03:17 AM |
| Pear Audio Cables - Only $7,250!! | sdclc126 | Everything Else | 13 | 29th December 2007 06:09 PM |
| Oritek Audio X-1 Cables | Spiritzly | Swap Meet | 0 | 6th August 2006 06:01 PM |
| Colors of Audio Cables | Glen.Yule | Car Audio | 2 | 13th November 2004 09:47 AM |
