| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#51 |
hello
I'd love to provide the Stepped switches.However,I hope that there is someone who can collect payments and items for me.By the way,I'm not good at English. |
#52 |
let's get going..
most of us have a paypal account so things could go very fast... J-P. |
#53 | |
diyAudio Senior Member
You give up position #24 by putting a mechanical stop there, often just a small blocking screw. I don't think there's a way to have all 24 pos. and have a stop at the same time... Not having a stop there would be risky as you could go from dead quiet to full blast by just one click. Cheers,
Frank |
#54 |
of a mechanical soultion something that prevents the KNOB from turning, so a deadstop, a small pin or so, attache to the bottom of the knob not visible from the front...
J-P gezondheid, das iets wat hier maar triestig opgevolgt wordt! |
#55 |
I would just sacrify one of the lowest volume position, for the stop. I'd rather have full gain (if needed) and don't have for instance -60dB position (as I never use it anyway). But stop is definitely required.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#56 | |
The problem is that you don't have enough space to put anything on these ELMA switches. Cheers,
Frank |
#57 | |
That's a possibility but for all practical purposes I find 23 pos. more than I ever need. At home I have attenuator usually set between ps. 9 and 11. If you use a switch to mute the preamp then you could consider that infinite att. and pos. -24 if you like. Cheers,
Frank |
#58 |
Stepped Attenuator
#59 |
Hey guys ! If group buy is happening on the 24 stepped one call me ! solomon_choi@yahoo.com.hk
#60 | |
Do we get a volume discount, if we buy many of them? Do you off them as kits, and fully assembled? Randy |
| Cheap stepped ladder attenuator. Coarse and fine. | OzMikeH | Parts | 2 | 1st January 2008 01:51 AM |
| Looking for a good source for attenuators | jduffy | Tubes / Valves | 4 | 18th January 2007 04:11 AM |
| Source for PEC mono attenuators? | Colescuttle | Chip Amps | 3 | 1st January 2007 11:04 PM |
| How should I set up my ladder attenuators? | Spasticteapot | Parts | 2 | 5th November 2006 03:04 PM |
| Remote stepped LADDER NETWORK attenuator w/ source selector | cartman | Swap Meet | 9 | 28th May 2006 07:37 AM |
| Page generated in 0.10220 seconds (79.70% PHP - 20.30% MySQL) with 11 queries |
