Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th December 2012, 02:10 PM   #1
Firochromis's Avatar
Default Help Me Identify a Roederstein MK3 Resistor
Hi people, can you help me identifying these resistors. All I know is they are Roederstein MK3's.
Old 21st December 2012, 12:28 AM   #2
Speedskater's Avatar
Do you mean the resistance value?
Or do you need more information about the MK3 series?
Kevin
Old 21st December 2012, 04:01 AM   #3
Sorry
l mean the resistor values.
Old 21st December 2012, 05:16 AM   #4
I do not know if the colors are right but the top resistor band colors read as follow:
blue yellow brown black brown red value = 641X1 tolerance 1 % temp=50ppm
bottom
brown black black brown brown red value = 100X10 tolerance 1% temp=50ppm
Please double check the colors.
Old 21st December 2012, 05:22 AM   #5
Hi again.
Just in case you want to know how to read the resistors here it is a link that explain how to read resistors.
link:47 ohm Resistance Pack-1/4 Watt (10 Nos.) [TPS-00457] - Rs.4.00 : :+: www.onlineTPS.com - Electronics and Robotics Components Shop - India, Components at your Doorstep - Satisfaction Guaranteed
Old 21st December 2012, 06:57 AM   #6
tauro,
Thank you for the #4 message, and #5 message is most welcomed.
BTW, upper is 681R, bottom one is 1K.
Old 21st December 2012, 07:21 AM   #7
Originally Posted by Firochromis View Post
tauro,
That is correct.
Sooner or later you end up with TANDBERG
Help identify and replacement of ? resistor devilsindetails Tubes / Valves 13 19th May 2012 04:57 AM
Roederstein replacements? phrarod Tubes / Valves 0 28th November 2009 05:18 AM
Why triode Mk3 is louder than stock Mk3 Wieslaw Lipowsk Tubes / Valves 5 14th June 2007 01:18 PM
What is an MK3 resistor ericpeters Parts 1 15th February 2006 01:01 PM
Roederstein cap ID please redrabbit Parts 5 25th January 2006 07:46 PM
Copyright ©1999-2013 diyAudio
