Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Help replacing/building a control unit
Old 12th April 2013, 09:17 AM   #11
sidduj143 is offline sidduj143  United Kingdom
Hi Plagasul,
When you have the original Potentiometer, why would you want to buy a 6pin maleDIN and do the soldering? Connect/solder the cut cables on the Potentiometer with the same matching color wires on the other side.
Old 12th April 2013, 01:51 PM   #12
plagasul is offline plagasul
Hello, thank you for your reply.
Maybe I do not understand well or have not explained myself well.
My volume control is working fine, the broken part is in the other side of the cable: the miniDIN connector that goes to the subwoofer.
So on one side of the cable I have a working volume controller, and on the other side, I have 5 cables.
I want to solder those cables to a miniDIN connector, to be able to plug it into the subwoofer, and so I can control the volume.
And my problem is that I do not know how to deduce the color code, as in what cable to solder to what pin in the miniDIN. If this can be deduced from the PCB, could you please explain to me how? that would be greatly appreciated.
I have started a specific post for my problem, with images and links and maybe there the problem is explained better.
Thank you VERY much for your help.
Old 12th April 2013, 01:52 PM   #13
This is the other post
help, volume control unit, fix connector, creative 4.1 4400
Thanks again
Old 14th October 2015, 10:54 AM   #14
chsarathi555 is offline chsarathi555
yes, someone pls post on how to fix this on this end of the cable.Have the same problem
Help replacing/building a control unitHide this!Advertise here!
Replacing transport unit on Marantz sacd player stvnharr Digital Source 4 24th March 2010 08:45 PM
Replacing a drive unit - impedance question chap2 Multi-Way 1 25th November 2006 07:54 PM
Think I blew it replacing laser unit kora Digital Source 7 5th June 2005 05:30 PM
Replacing a CDM9/65 laser unit Sarion Digital Source 22 17th April 2004 04:57 PM
Building a power supply unit. S.C Chip Amps 4 6th August 2003 09:59 PM
