Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Roederstein 'BAKELITE' series EK capacitors - "Living Legend" OR "Looney Legacy" ...?
Old 20th December 2012, 02:05 PM   #21
The Space Egg Corp is offline The Space Egg Corp  England
The Space Egg Corp's Avatar
Hi again Elvee
There was some speculation earlier...
...that the casing's might be something OTHER than Bakelite...
...perhaps an 'improved' sort-of Bakelite.
( I believe Phenolic, was kinda the MKII Bakelite...
...sort-of anyhow ! )
Well...
...the brown/red case, is absolutely TYPICAL of Bakelite...
...which did seem to be made in 'certain' colours...
...including ORANGE.
A friend of mine showed me some Bakelite objects ( he collects them ! ).
Orange is/was an unusual-colour he told me.
He also told me BLUE is 'quite rare' and VERY collectable...
...I'll take his word on all that !
Just looked at a brown/red Roe-cap under a microscope.
The casing is 'ever-so-slightly' chipped.
And indeed !...
...SAWDUST was mentioned earlier as well...
( my collector friend also mentioned this )
...there are what looks, remarkably like small 'wood-colour' particles, emerging from the surface of the casing.
Impossible to see with the 'naked eye' of course.
I believe also the 'porousity' of Bakelite was mentioned earlier also.
Perhaps there IS a 'controlled-venting' from an otherwise, epoxy-sealed case...
...through slightly porous Bakelite.
Perhaps THIS was one of the main ideas of using the otherwise 'fairly obsolete' material; way into I think, the 70s' & 80s'.
Bakelite also seems entirely, non-resonant ( or fairly, at least ).
All these 'high-end' capacitor manufacturer's sales-pitches; are constantly on about, anti-resonance this, anti-resonance-that.
Maybe the 'top-boffins' at Roederstein had figured this out YEARS before...
...and implemented it as standard, at a normal, sensible cost ?
Cheers.
Si.
Old 20th December 2012, 02:55 PM   #22
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by The Space Egg Corp View Post
Hi again Elvee
Well...
And indeed !...
I don't know, I think it is a variety of Novolac, with proper additives and loads, but as I said, I am no material specialist.
Non-resonant (mechanically at least) is complete BS for me and it certainly was for the designers of these caps.
It is something audiophools are preoccupied about, but no serious engineer would care about it for more than half a second.
German engineers were down to earth and not superstitious at all (which is why they made such good products), and that is certainly not something they looked into.
Avoiding the movement of internal parts during vibrations and shocks is a concern, but with a radial capacitor filled with viscous liquid, that is not too much of a problem.
Electronic resonances could be more problematic, but they are well under control, and it has nothing to do with the bakelite or other case material.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 20th December 2012, 03:11 PM   #23
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 Roederstein 'BAKELITE' series EK capacitors - "Living Legend" OR "Looney Legacy" ...?
The casings certainly looks and acts like a wood flour filled, phenolic based resin. I've always found them to be excellent caps as long as they aren't run over temp or current.
Paradise Pre-reg PSU PCBs
Old 20th December 2012, 04:05 PM   #24
Elvee's Avatar
Found one more example, a 470µ/16V (used). Esr @1K is 72mΩ
Old 23rd December 2012, 05:01 PM   #25
Exclamation Leo Baekeland
Invented by Belgian...
...Leo Baekeland...
...in 1907 !
( Bakelite, that is; not the capacitor ! )
Cheers.
Si.
Old 25th December 2012, 10:59 AM   #26
Talking Seasons Greetings
Old 25th December 2012, 05:09 PM   #27
Elvee's Avatar
I found some more in my stock, including the grey one.
I don't know if this color has a special meaning.
The esr @1KHz for this NOS 100µ/35V is 131mΩ
The 220µ/40V of more conventional aspect measure 67mΩ. They date from 1980 and have served a harsh duty: they were filter caps in a modular DC/DC converter.
Old 27th December 2012, 03:55 AM   #28
PedroDaGr8 is offline PedroDaGr8  United States
PedroDaGr8's Avatar
Interesting coincidence, the other day at work I pulled some boards out of an old chart recorder. I noticed some of the boards have what look like ROE rectifiers in them. Same exact bakelite case, very interesting but with ROE and ~ on the surface and four pins. Plus a bunch of Frako Caps (west germany) and loads of other stuff. I didn't know much about the rectifiers but happened to see this.
Old 27th December 2012, 05:25 AM   #29
wrenchone is offline wrenchone  United States
wrenchone's Avatar
One way to find out what it is - touch an edge with a soldering iron. If it melts, it's not Bakelite, but something else. Bakelite is brittle, so it's a bitch to mold in thin cross-sections. The cap might use another material like PBT, a plastic commonly used to mold things like bobbins where injection vs. transfer molding is desired, but with a better resistance to heat than something like nylon.
Old 28th December 2012, 09:21 AM   #30
MRupp is offline MRupp  Germany
MRupp's Avatar
FWIW, It looks like Brinkmann still uses some Roederstein EKR caps in his products. If quality or reliability was an issue I guess he would throw them away: brinkmann audio
Martin Rupp
Roederstein 'BAKELITE' series EK capacitors - "Living Legend" OR "Looney Legacy" ...?Hide this!Advertise here!
Question about "old" technology: the wiiide baffle of the Boston Acoustics "A" series River757 Multi-Way 28 26th September 2015 12:34 PM
The ubiquitous 1/2"...um....3/4"...er 1" ?? polycarbonate "dome" tweeter River757 Multi-Way 16 8th July 2013 12:45 AM
3-way with big (10") woofer and monitor (6.5"+1") on top like "Tarkus" proxii Multi-Way 16 30th October 2012 12:43 PM
Schematic for AVI CD Player "S21MC" from "Labaratory Series" needed tiefbassuebertr Digital Source 0 3rd June 2012 08:46 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
