Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th December 2012, 04:02 AM   #21
MGH is offline MGH  United States
Originally Posted by The Space Egg Corp View Post
Yeah...
...loads of schematics like that posted on the net all the time...
...but anyhow...
...what amp is it anyway ?
Schematic will be on Google for sure.
Cheers.
Si.
Please see my PM. Thanks.
Old 18th December 2012, 04:09 AM   #22
Originally Posted by DF96 View Post
The 2.2k resistor is a grid stopper. It reduces the RF gain of the valve so it can't turn into an oscillator. A non-inductive wirewound might not be best here, because it could have too much capacitance. Just use a carbon film or metal film.
Hi DF96, a grid stopper...that's what it's called, and thanks for explaining the purpose of this resistor, to prevent oscillation. I tend stay away from carbon film because of my concern for instability but many seem to like carbon film or composite in this position. Do you have a particular brand of carbon film or metal film in mind? Your experience on this matter would be appreciated.
Old 18th December 2012, 12:47 PM   #23
The Space Egg Corp's Avatar
If you want the only carbon worth 'sniffing at' IMO...
...check out 'Kiwame' carbons.
Si.
Carbon - Vintage sound.
Metal film - Edgey sound.
Wire wound - Wire sound.
More useless hyperbole probably.......................................... .
Old 18th December 2012, 06:30 PM   #24
DF96 is offline DF96  England
Instability? Are you getting carbon film and carbon composite mixed up? The latter can be unstable, over periods of decades. Some people prefer carbon comp for stoppers, but I don't think this is necessary.
I don't worry about brands. The circuit is far far more important than component brand. Many (but of course not all) of those who worry about brands do so as a substitute activity for their lack of circuit knowledge, in my opinion.
Old 18th December 2012, 06:50 PM   #25
You're right, I was thinking of carbon comp being unstable.
Old 18th December 2012, 07:08 PM   #26
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
...make your own resistors...
..." now that's DIY dude ! "
Flat-wound...& more acurrate than Vishay-foil...
...$$$$$$$$$$$$$$$$$$$$$$$ left over, to buy LP's with !
Do you find this unusual?
Not so
I have been making my own for ages (think thousands of them, for over 30 or 32 years).
For both reasons: nil cost, but the main one is getting them in any odd value, such as .065 ohms , perfect for limiting at exact 10 A in short protection circuits.
I buy 0.50 mm diameter Constantan (although now it comes under the commercial brand CuNi44), which is solderable.
Casa Astri - Proveedores Industriales - Resistencias Electricas - Aislantes Térmicos - Instrumentos de Medición - Controles de Temperatura - Tubos de Cuarzo - Cerámicas Tecnicas - Caloventores - Calefactores Electricos - Bimetales - Pantallas Ifrarro
.065 ohms is a short strip measuring 1 inch , as easy as they come.
I have 2 pads on the PCB separated by 20 mm, so the wire is parallel to it , 5mm away.
Wire resistance is 2.5 ohms/Meter , very easy to calculate.
So 0.1 ohms means 4 cm and so on.
100 grams of wire cost a few dollars and provides 1 year supply, how's that?
For higher values (0.33 ohms ; 0.47 ohms) I flat wind them around strips of "micanita" , a flat sheet material made out of mica.
Old 18th December 2012, 09:35 PM   #27
Are Kiwame resistors carbon comp or film? According to Partsconnexion they're carbon film.
KIWAME - 5 Watt Carbon Film Resistors
Old 18th December 2012, 09:55 PM   #28
Triodethom's Avatar
as DF96 pointed out it a grid stopper resistor . Thus some inductance the small amount in those values should reduce not increase rf pass through . As for the plate and screen resistors more inductance is desired. Transformer coupled outputs state an inductance value , it part of how they work . All the signal passes through the grid resistor so try some ans see what you think.
Old 18th December 2012, 10:05 PM   #29
Audio transformers typically need many 10's or 100's of H. Resistors, whether wirewound or not, are going to be in the uH or nH region so won't contribute much inductance.
Just tried a Wire Wound pot for volume. Shoog Tubes / Valves 6 9th April 2012 10:43 PM
Wire Wound Resistor or Inductor? 69stingray Parts 5 30th January 2010 01:24 AM
Why not wire wound potentiometers for volume? tem00 Chip Amps 18 16th January 2009 01:48 PM
Wire Wound Pontentiometers - resistors neazoi Tubes / Valves 1 12th January 2009 11:08 AM
Wire Wound Resistor Failure? jjai Solid State 6 3rd March 2005 07:32 PM
Copyright ©1999-2013 diyAudio
