| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#11 |
Some probably worthless generalizations-
Inductance of lower values is usually too low to worry about in the audio region. Non-inductive winding patterns don't work as perfectly as one might like and can degrade things like self-capacitance. Noise will usually be better than anything but metal foil ($$) parts. Tempco will be better than any audio project needs. Use caution if the WW is used for feedback around wide bandwidth parts like opamps. It may be audio, but you might be dealing with a 50 MHz GBW part that isn't aware of that! The peak power handling ability of many WW resistors is extremely good- see Ohmite and Dale (Vishay) notes on this. Given a roll of resistance wire, like manganin which is solderable, you can wind perfectly good WW resistors of any value you like and in any of the low inductance patterns you desire.
I used to be an audiophool like you but then I took an arrow to the knee. |
#12 |
A bit of inductance does little harm in audio, except in low impedance circuits, provided it is damped by some resistance too which is exactly what happens with a wirewound. Wirewound are usually the lowest noise resistors, because all you get is the unavoidable thermal noise. Other resistors have extra noise mechanisms too.
One proviso: it might be possible for wirewounds to introduce magnetic coupling between circuits so don't put them near each other and parallel unless a bit of coupling would do no harm. |
#13 |
Hi Conrad.
SUPERSTAR ! Not worthless... GEMS ! Yep...I got some resistance-wire, & DIY hyper-matched source-resistors are in production... ...make your own resistors... ..." now that's DIY dude ! " Flat-wound...& more acurrate than Vishay-foil... ...$$$$$$$$$$$$$$$$$$$$$$$ left over, to buy LP's with ! Hi DF96 Nice tip on the possibility of 'magnetic coupling'... ...hadn't thought of that one before. Next board, designed with that in mind. Thanks ! Cheers. Si. |
#14 |
#15 |
Hi MGH
Is it the 'grid leak' resistor you mean ? Anyway... ...these are always VERY high value. It is possible to make this a wire-wound... ...I just scored a pair of 500k WW's on eBay ( 350volt, I think )... There are lower voltage ratings out there as well. But probably, you might want to use a 'High Stability' metal-film resistor. This most likely has a 'spiral cut' anyhow, as well. I don't think you're at all likely to get oscillations ANYWHERE using decent WW's. Now trashey NOS carbon-compositions are another story... ...as said, I think before... ...we've measured 'brand new' NOS ones that are simply either WAY high (bad sign of stability), or just plain 'open circuit'. I don't think you will have 'inductance problems' ANYWHERE with WW's... ...correct or 'over-rated' Voltage spec. is what's important... ...CHECK IT...not all WW's go to say 350v; I would prefer to see 500v or higher rating for a 350v PSU'ed amp. The only real danger of inductance, I believe, is at very high frequencys, as said before... ...and very-low Ohm values, which aren't in most valve amps anyway. Try it and see, is the best test. You might be surprised to hear just how good WW's sound; especialy compared to rotten old carbon resistors. Never need replacement either. Well worth the extra 25cents ! Cheers. Si. |
#16 |
Thanks Space Egg. Please see the figure. I'm not sure what you mean by "grid leak" resistor, but I'm talking about 2.2 kOhm resistor (R6). I want to use noninductive WW resistor in this location.
In fact, I want to use noninductive WW for 100 Ohm screen resistor (R18) and 10 Ohm plate resistor (R12), as well. Would you say noninductive WW are appropriate for all these locations provided the voltage and wattage requirements are met? |
#17 |
Hi MGH
Can you post a decent res. ( readable ! ) schematic of the WHOLE of the circuit you are interested in. I don't think the 2.2k will have ANY 'worrying' inductance at all. The smaller ones might... ...but again, perhaps ONLY an issue in a high-frequency RF amp. I ain't the world's greatest 'expert' by a long-shot... ...but let's have a look at the whole schematic. Be nice to see what you're making anyhow. Cheers. Si. Also...where did the schematic come from ? Is it a tested design ? Is it a 'retro classic' etc. etc. |
#18 | |
#20 |
The 2.2k resistor is a grid stopper. It reduces the RF gain of the valve so it can't turn into an oscillator. A non-inductive wirewound might not be best here, because it could have too much capacitance. Just use a carbon film or metal film.
| Just tried a Wire Wound pot for volume. | Shoog | Tubes / Valves | 6 | 9th April 2012 10:43 PM |
| Wire Wound Resistor or Inductor? | 69stingray | Parts | 5 | 30th January 2010 01:24 AM |
| Why not wire wound potentiometers for volume? | tem00 | Chip Amps | 18 | 16th January 2009 01:48 PM |
| Wire Wound Pontentiometers - resistors | neazoi | Tubes / Valves | 1 | 12th January 2009 11:08 AM |
| Wire Wound Resistor Failure? | jjai | Solid State | 6 | 3rd March 2005 07:32 PM |
