Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
2SD786 datasheet translation
Old 14th December 2012, 05:09 PM   #1
RayCtech is offline RayCtech
Default 2SD786 datasheet translation
I need help to translate the pin 1, 2 and 3 to B, C and E for the ROHM 2SD786 transistor. Datasheet attached.
Old 14th December 2012, 05:24 PM   #2
StevenOH is offline StevenOH  United States
StevenOH's Avatar
d/s pinout
The truth is out there. Who can handle the truth?
Old 14th December 2012, 05:37 PM   #3
Originally Posted by StevenOH View Post
d/s pinout
Thank you!!
Could you post or send an email with the data sheet attached ?
Old 14th December 2012, 05:58 PM   #4
StevenOH's Avatar
(If your OS is capable of doing this) highlight the text, the arrow will appear. Click on it, the menu will appear, click on the "Search with Google" (usually, Google option must be added).
Otherwise, just copy and paste the text in Google -you will find plenty of d/s.
Old 14th December 2012, 06:05 PM   #5
Mooly's Avatar
If its just lead identification you are stuck with then using a normal DVM on its diode range, the BASE is the lead that, when you connect the RED meter lead to it you get a reading to the other two leads.
The collector is the middle one, and now you have found and identified the base......
2SD786 datasheet translationHide this!Advertise here!
Russian-English Translation of 4P1L datasheet 316a Tubes / Valves 21 2nd January 2017 05:37 PM
Rohm very low noise transistors 2SD786 and 2SB737 ticknpop Swap Meet 1 7th March 2011 12:50 PM
Have ROHM 2SD786 - want ROHM 2SB737 RayCtech Swap Meet 0 8th April 2010 09:14 AM
Translation needed lumanauw Solid State 18 17th June 2006 01:32 AM
