Could you please tell me what is the value of this capacitor? I am confused. - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 11th December 2012, 06:26 PM   #1
csom's Avatar
Question Could you please tell me what is the value of this capacitor? I am confused.
Hi all,
I purchased these caps (kindly see the attachment) from a local shop as 10uF . I want to use them in the signal input section of an amp.
My questions are
1. What is the exact value of these?
2. Can I use them in the signal path?
3. What type they are of?
Thank you
Warm regards
Som
Old 11th December 2012, 06:32 PM   #2
DF96 is offline DF96  England
Could be 10uF. Could be 10nF. They appear to be film caps, so unless they are huge I would guess 10nF at 100V. Might work as input cap to a valve amp with a reasonably high grid resistor.
Old 11th December 2012, 06:36 PM   #3
csom's Avatar
Thank you DF96, for your kind and prompt reply.
But i want to make sure as I need two 10uFd in my graphic equalizer output
Here is another photo for the comparison of the size.
Old 11th December 2012, 07:14 PM   #4
Elvee is offline Elvee  Belgium
Elvee's Avatar
10µF/10%/100V.
The type could be almost any plastic: mylar, polycarbonate, polypropylene (except polystyrene).
Construction could be metalized or foil.
Anyway, they should be perfectly suitable for signal path applications
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 11th December 2012, 07:21 PM   #5
csom's Avatar
Originally Posted by Elvee View Post
10µF/10%/100V.
Thank you so much Elvee! Much apreciated!
regards
Som
Old 11th December 2012, 07:23 PM   #6
Apex Jr is offline Apex Jr  United States
10µF/10%/100V.
For sure 10Uf 10% 100V
Need to see the side where the leads come out, might be PIO Paper in Oil
type caps
Old 11th December 2012, 07:31 PM   #7
csom's Avatar
Default side view
Thank you so much Apex!
Here is the side view
Old 11th December 2012, 07:34 PM   #8
Not paper in oil.... Most likely Mylar or poly caps
Old 11th December 2012, 07:42 PM   #9
csom's Avatar
okay! thank you again Apex
What is the best cap type for signal path , I mean what type should I tell vendor when i purchase , could you please guide me ?
Old 11th December 2012, 08:19 PM   #10
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
Polypropylene would be the better choice, and reasonably easy to obtain; polycarbonate 2nd choice, and Mylar last--but still better than an electrolytic. Polystyrene and teflon would be much superior, but you won't find them at any reasonable cost or size.
Mylar and polycarbonate films seem to be more compact than other film types. Then there are two types of construction: metalized film and film and foil. The second is higher quality, rather more expensive and larger. I would settle for metalized film.
How to install a motor run capcitor Alexander C Tubes / Valves 4 11th October 2010 05:20 AM
Confused - Can You Help? Steveal Full Range 16 1st July 2006 09:59 AM
Help Confused jwatts Subwoofers 2 26th June 2006 12:12 PM
i'm confused ... sss Multi-Way 5 11th May 2006 01:03 AM
Capcitor type for Vref fmak Digital Source 41 4th June 2004 11:03 AM
Copyright ©1999-2017 diyAudio
