Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th December 2012, 04:41 PM   #1
Default can you ID a bad component on a pcb
i have a Phase Technology DP 2000. a few audible clicks at last start then no power. i have removed the cover and checked incoming voltage and fuses, all good. i have attached 4 pictures of a component on the pcb, two good and two looked burned. can anyone id these? if so, how would i check them and or replace?
J.C.
Old 9th December 2012, 05:02 PM   #2
The first two pictures show a transformer that is showing signs of running on the hot side the second Piccy looks worse and also the electrolytic capacitor next to it .. This is a class d amplifier you really need someone who knows this amp or is expirienced. Do you have any test gear . have you done any fault finding ... To be honest i think this thread would be best in class d section ...
Old 9th December 2012, 05:06 PM   #3
weinstro's Avatar
J.C.
It's a transformer. Just replace. But, you need to make an effort to find out why it's damaged. Otherwise, you're going to be treating these like expensive fuses.
If this is a Class D design, this is possibly a switchmode transformer, in which case the primaries are driven by a pair of transistors, and the output are connected to a pair of diodes, setup as a full-wave rectifier. Likely, the one or more drive transistors are damanged, too.
Rob
Old 9th December 2012, 05:15 PM   #4
And a plethora of other coponets .. you can bet your bottom dollar there will be a few smd components that need replacing too. That transformer is most likley wound as a custom job for the amplifier in question . With no scematic repairing this amp will be A large PITA.. If you are not set up to work on this stuff and have a fair amount of knolage . it would be best to send it back to its maker for repair ..
Old 9th December 2012, 05:15 PM   #5
i will repost in class d
Old 9th December 2012, 05:18 PM   #6
this whole pcb is made in india, Celltronixs in think. i found the entire unit on web, it was for a Kliptsch subwoofer, but the nameplate has same model # and specifications. $280.00. is it worth to just buy this and replace the whole thing, or send back to manufacturer?
Old 9th December 2012, 06:00 PM   #7
Could you post a piccy of the entire internals ???
Old 10th December 2012, 04:52 PM   #8
Default Pic
Here is a pic of whole unit
Old 10th December 2012, 05:07 PM   #9
Elvee is offline Elvee  Belgium
Elvee's Avatar
J.C.
I am not even sure the transformer is faulty: the flux band seems to have been forcibly torn away, but that is not the kind of incident that occurs naturally....
Such transformers are extremely resilient, even when they have been severely abused.
The Elytics look like more likely culprits. One is visibly damaged, and others have probably suffered too, even if there is no visible sign.
Anyway, the symptoms you report are coherent with faulty caps.
Replace all of them, and retest.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 11th December 2012, 07:36 PM   #10
xjr100 is offline xjr100  Europe
Seems that small electrolytics on both sides are damaged....
Auricap XO, Mundorf capacitors, coils, MSolder, terminals, DH-Labs interconnect & speaker cables, internal wiring for DIY & upgrades are here: www.audiohobby.eu
Component ID ssb2005 Parts 2 9th September 2012 10:44 AM
Help - component ID and suggestions thickmike Parts 14 2nd June 2011 01:28 AM
ID SMD component glen65 Parts 2 24th September 2009 12:47 PM
can you id this component moss99 Parts 8 27th March 2009 08:02 AM
ID of component Organist Solid State 10 2nd August 2007 06:52 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
