Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th November 2003, 02:18 AM   #1
BobEllis's Avatar
Default powerstat connections
Can anyone tell me how I should connect my "new" superior electric panel mount powerstat, type S-12008? There are 5 terminals I presume that I connect power to two of them and get adjustable output from another other two. But which pairs?
Thanks a lot.
Old 8th November 2003, 05:28 AM   #2
Brian Donaldson's Avatar
I also buoght one on ebay. But mine is a Superior Powerstat 3.1KVA, but I can't read the model number.
As for hookup, use your imagination.
On mine, as you move around the coil clockwise as viewed from the back, the taps are numbered 1,5,2,4 with the wiper numbered 3.
If you want your output to be from 0 to 100% of line voltage, Connect 4 to cold, 1 to hot in and 3 to hot out.
If you want output to be from 0 to +- 130% of line in, hook 4 to cold, and 5 to hot in. (3 is always hot out).
If you feel really brave, hook 2 to cold in and 5 to hot in then use 4 for cold out and 3 for hot out and you'll have -30% to 160% of line voltage.
Just be safe and check output with a ac volt meter befor you connect a load. and If it humms too much (teach it the words), you may be saturating the toroid.
c3g connections garbage Tubes / Valves 8 16th October 2010 08:51 AM
Powerstat Variable transformer / Variac speaker Swap Meet 0 16th May 2007 03:20 PM
powerstat variable transformer 22 amp elghosto Swap Meet 0 7th October 2005 04:46 PM
HELP with connections Tony.ca Multi-Way 7 23rd May 2005 11:56 PM
1.3 kVA Superior Electric Powerstat Variac CCOZGO40 Swap Meet 2 7th November 2003 12:27 AM
Page generated in 0.06146 seconds (69.93% PHP - 30.07% MySQL) with 10 queries
