Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Saving vintage resistors (in theory!) in Quad II amps
Old 29th November 2012, 06:32 PM   #11
mickeymoose is offline mickeymoose  Canada
Elvee: You need to clean out your parts bin! These are not even carbon film, but carbon composition resistors. Menace of servic techies everywhere! E
Old 29th November 2012, 08:28 PM   #12
Elvee is offline Elvee  Belgium
Elvee's Avatar
I thought the topic was about carb comp resistors?
Originally Posted by johnm View Post
I'm well aware that they are[/U]), could one bake the resistors to drive out this moisture? Hi-Fi Collective mention the following baking process on their website for NOS Allen Bradley resistors:
[I]"...Allen Bradley resistors are carbon composite, being made of an organic material they do have the tendency to absorb water from the atmosphere.
Or maybe the OP is mistaken?
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 29th November 2012, 08:49 PM   #13
What vintage is the Quad? I cant recall carb comp beeing used after the mid/late 60's (tube time). And I cant believe that Quad would have ever used them
Low value Rs (<100 Ohm), like in your picture, sometimes where wirewound, differnt animal, but you can not tell from the outside
The reason I mentioned the temperatur (dis)coefficient of carbon resistors was an experience I had in a hospital, consulting, where the techs where using CF resistors to repair lifesafety equipment. Scarey! E
Old 29th November 2012, 08:59 PM   #14
Elvee's Avatar
I have seen equipment as late as the nineties using carb comp (exclusively US)
Old 29th November 2012, 09:09 PM   #15
Ouch, that hurts! E
Old 30th November 2012, 08:40 AM   #16
405man is offline 405man  Scotland
With care you can remove the resistor contents and preserve the outer case, you could then insert modern resistors and re-seal the ends
Stuart
Saving vintage resistors (in theory!) in Quad II ampsHide this!Advertise here!
replacing vintage resistors Trileru Parts 3 21st November 2012 04:34 AM
Saving efforts boyofwax Full Range 1 5th December 2010 03:48 PM
FS: Vintage Precision Wire-wound Resistors theAnonymous1 Swap Meet 11 20th June 2009 10:41 PM
Wattage of vintage resistors ? nio101 Tubes / Valves 14 16th February 2009 09:40 PM
Does anyone know the power rating of vintage dog bone resistors? tom1356 Parts 4 12th January 2007 08:28 PM
