Looking for 48V phantom power supply DIY - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th November 2012, 03:03 PM   #1
Default Looking for 48V phantom power supply DIY
I gave up.
I tried to build 48V supply for mic.
I use 12V to run my device & I need to make 48V from 12V
Any solutions?
I didn't find any reasonable solution.
Idea to build generator with NE555 + trafo + 48V stabilizer is ok?
If You have any experience, please share.
thx
Old 20th November 2012, 03:34 PM   #2
KatieandDad's Avatar
Rod Elliot provides details of providing a phantom PSU for mics.
I would use a simple flyback circuit to produce 48V from 12V.
Old 20th November 2012, 03:37 PM   #3
Minion is offline Minion  Canada
12v AC can be turned into 48v DC using a voltage tripler ......
12v AC = 17v DC x 3 = 51v DC which you can regulate to 48vDC with a LM317
I have built a few mic preamps that used this method to get 48v Phantom ......
cheers
Old 20th November 2012, 05:36 PM   #4
I've got only 12V DC, not AC. That's the problem.
"simple flyback circuit" - which? MC34063 or LM2585?
I need details & working solution. Please.
It's quite simple thing but I can't find good solution.
Old 20th November 2012, 05:48 PM   #5
WSJ is offline WSJ  United States
WSJ's Avatar
The PB23 is for powering phantom powered microphones with 48VDC. Since the unit uses a 100KHz switching power supply there is no audio noise generated. It has an output pull down resistors so it will work with any mixer.
Rolls Corporation - Real Sound - Products PB23 Phantom Power Adapter
Old 20th November 2012, 08:01 PM   #6
I rather would do it myself.
I think I try to make with MC34063. Now I wait for components...
So, inside this box they put some electronics
Old 20th November 2012, 08:32 PM   #7
I designed with LM2587 tools like this.
Your opinion will be much appriciated.
I decided to put max Iout as 70mA, but I think It would be to much.
thx for interesting
Old 21st November 2012, 01:10 AM   #8
WSJ's Avatar
The manual has a schematic. For about $25 on ebay, you could get the box with all the connectors and change the circuit to your design. Evaluate both circuits and see if you can improve the 48V converter.
48V phantom supply for mic 454Casull Instruments and Amps 9 7th August 2012 12:44 AM
Slow ramp up/fast ramp down 48V phantom power (circuit design) magnus0re Analog Line Level 5 19th June 2011 08:42 PM
Diy Mic preamp with 48v phantom power cheeseburgerjoe Parts 12 16th September 2010 11:33 PM
xlr and 48v phantom power to pc oublie PC Based 7 14th November 2009 03:40 PM
sounds silly .. but do i need a 48v phantom power ? Ahmad_tbp Solid State 8 3rd February 2007 10:36 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
