Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th November 2003, 06:26 AM   #1
MWP is offline MWP  Australia
Default Mains filtering.
Hi all,
I have a very annoying problem where a bar fridge in the same room as my audio gear is causing very loud pops on my speakers when the compressor turns on/off.
Is there an easy way to fix this?
A mains rated filter cap across the fridge thermostat, etc?
Thanks.
Old 4th November 2003, 06:46 AM   #2
Cradle22's Avatar
Hi!
Try putting a pre-manufactured filter in series to the fridge power line, but pay attention to the power rating.
I always have one or two lying around...
Bye,
Arndt
A Sacrifice For Freedom
Old 4th November 2003, 06:48 AM   #3
mcp is offline mcp  United States
There is probably a relay that switches the compressor on and off and everytime this happens, the relay contacts arc. Install a "X2" type capacitor across the relay contacts and it should cure the problem. You can start with 0.1uF/250Vac X2. Please note that this will be at mains voltage, therefore the necessary safety precautions must apply. Cheers.
Michael Chua
Old 4th November 2003, 07:05 AM   #4
frugal-phile(tm)
planet10's Avatar
Thorsten (Kuei Yang Wang) has a DIY shunt mains filter article out on the www somewhere that you might find helpful. (I couldn't find it on his web site)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 4th November 2003, 07:51 AM   #5
Electrons are yellow and more is better!
peranders's Avatar
I have a feeling that you will need a transient filter like a VDR across the live neutral. Size K14 or K20 and 250 VAC, or 115 VAC. Start with a simple and cheap VDR.
/Per-Anders (my first name) or P-A as my friends call me
Old 4th November 2003, 08:16 AM   #6
Additionally take voltage drop into account. Some compressors draw quite a lot of current so it is also advisible to have seperate mains wiring to both outlets where the fridge and the HiFi are plugged in.
Charles
Old 4th November 2003, 10:58 AM   #7
Thanks for the tips guys.
Ill have a look tomorrow.... we are just starting to get hot weather here so having the bar fridge on would be handy
Old 4th November 2003, 05:30 PM   #8
antomas is offline antomas  Europe
Maître sans marteau
somewhere=tnt-audio.com
Ciao, Massimo
Old 4th November 2003, 05:44 PM   #9
frugal-phile(tm)
planet10's Avatar
Thanx for that
dave
Old 5th November 2003, 05:37 AM   #10
EE_Mark is offline EE_Mark  United States
Default Pops
The glitch on the power line is causing a pop in your system. There are two ways to approach this: Filter the glitch from the compresor or make the amp immune to the glitch. A combination of the two might be necessary. What kind of power amp? How much power? You might try putting 0.1 uF ceramic caps across the diodes in the bridge rectifier or, if the amp is not high powered, running it through an isolation transformer. Some of the better power strips for computers have some decent filtering in them. One of the power saving devices that you plug refrigerators into to save electrcitiy might even work.
Mark
Mains Filtering audiofanaat Power Supplies 1 2nd February 2009 11:41 PM
Filtering mains clicks/pops Ted205 Power Supplies 5 15th October 2008 03:11 PM
MAINS... simple, old style amplifier, plugged into mains electrical outlet (110) destroyer X Solid State 2 15th June 2008 02:31 PM
PS EMI filtering xyrium Parts 4 2nd November 2005 06:20 AM
AC mains filtering question thylantyr Solid State 4 26th March 2003 08:28 PM
Page generated in 0.12015 seconds (78.91% PHP - 21.09% MySQL) with 11 queries
