Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Morgan Jones Kapacitors
Old 13th November 2012, 06:37 AM   #11
disco is offline disco  Netherlands
disco's Avatar
+1
jaap
Old 13th November 2012, 06:42 AM   #12
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
anybody got pictures to look at? links? thanks....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 13th November 2012, 07:42 AM   #13
bayermar is offline bayermar  Germany
bayermar's Avatar
+1
one more caveman on my side of the screen...
Old 13th November 2012, 08:05 AM   #14
Brouilly is offline Brouilly  United Kingdom
Brouilly's Avatar
They are pretty big, this box is about 8" long. I thought I had the wrong order when they first arrived!
I spoke with Campbell at SD and he said that Morgan found significant improvement with the added leads when using multiple stages. I havn't had the chance to use them or compare them yet but I look forward to.
Strange creatures....
Broke solderer with delusions of grandeur
Old 13th November 2012, 09:35 AM   #15
On Hiatus
SY's Avatar
In terms of electrical connections, this is outlined in great detail in Valve Amplifiers, 4th edition. Basically, it's a Kelvin connection, one set of leads go to the supply, another set go to the load- they connect right at the cap foils, reducing the effect of ESR from the leads on coupling of ripple and signal between stages.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 13th November 2012, 11:42 AM   #16
disco's Avatar
Wasn't there a t-cap or something from Jensen with more than the obvious amount of connections? I'm talking 2004 or about.
jaap
Old 13th November 2012, 12:45 PM   #17
12B4A is offline 12B4A  United States
12B4A's Avatar
After seeing pg 374 (courtesy of google books preview) I understand how a single 4 lead kelvin cap would work. For 4 stages I have trouble imagining where the 10 leads would go because the basic premise is 4 leads per cap which (after consulting with my fingers and toes) would yield 16 leads if I were to assume 4 capacitors (because of 2x2 stage/channel) and extrapolate from what I currently understand.
Old 13th November 2012, 03:31 PM   #18
12B4A's Avatar
Does it look like this? Please say yes because I feel like I just solved a crossword puzzle.
Old 13th November 2012, 03:54 PM   #19
Triodethom is offline Triodethom  United States
Triodethom's Avatar
Thumbs up We have a winner
That's the idea for the ten leg but with resistors on both ends and the lead inductance added . So you did solve the cross cap puzzle.
Old 13th November 2012, 04:00 PM   #20
Triodethom's Avatar
The picture is of 8 leads . I am mising some here . Looked at page 374 in the book and am confused as to 4 leads on each end. Thanks for the insight .
Morgan Jones KapacitorsHide this!Advertise here!
Morgan Jones' CCS's Kay Pirinha Construction Tips 10 15th June 2012 06:41 AM
So how tattered is your Morgan Jones? Richard Ellis Tubes / Valves 8 5th January 2008 02:30 AM
Morgan Jones and cascodes Ryssen Tubes / Valves 37 11th July 2006 05:28 AM
MY Morgan Jones headamp. digi01 Tubes / Valves 9 25th April 2003 01:19 AM
