Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
"The Classic-D" - New Class-D Amp from Silicon Chip
Old 10th November 2012, 07:03 AM   #11
kpimage is offline kpimage  Australia
Originally Posted by alexcp View Post
An interesting part of the reference design is its scalability.
Yes the scalability is a good feature, designed to operate in the range of +/-40-60V.
A supply of +/-57V will produce 150W into 8ohm & 250W into 4 ohm with THD of 1%, but the filter capacitors used are only rated 63V which gets close or past that value with mains variation.
The another feature, is to bridge two modules to get 500W into 8ohms and run them of one of single supply with a transformer rated at 500VA or more.
Old 12th November 2012, 02:40 AM   #12
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
If you add mosfet gate drivers you can get well over 250 watts.
I have a design that will output 750 watts into 2 ohms.
I use the TC4420 mosfet gate drivers with 2 pairs of irfb4227's.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 15th November 2012, 12:56 PM   #13
Default Mosfet gate drivers
Hi Nigel, can you post a schematic of your circuit?
Interested amps that can drive difficult speakers with low impedance.
Old 15th November 2012, 01:13 PM   #14
ITS JUST THE APPLICATION NOTE CIRCUIT WITH tc4420 GATE DRIVERS.
I ALSO SCALED THE OVER CURRENT VOLTAGES TO GET MORE POWER.
Old 27th November 2012, 03:45 PM   #15
alexcp is offline alexcp  United States
alexcp's Avatar
The project is now on Silicon Chip's website.
Old 19th December 2012, 12:34 PM   #16
Default D-Class Kit for Sale
Altronics have the kits in stock. Selling for AU$69.95 complete one channel less power supply.
Altronics - K5181 Classic 250W Class D Audio Amplifier Kit
Old 25th December 2012, 03:33 AM   #17
Ian Finch is offline Ian Finch  Australia
Whilst it's nice to post what we see on the forum, this is the parts forum - why not post it in the Class D forum?
The other no-no is that this is copyright material from recent magazine issues! Guys, there are definite rules about that.
Ian
Old 26th December 2012, 09:47 AM   #18
Default Follow up
Originally I posted it under Class D section, but due to the copyright images the Web-Master move it to the parts section.
I've order two kits, and hopefully if I've receive them early 2013, I can start the building the project and post the result.
Old 10th June 2013, 09:46 AM   #19
Rainwulf is offline Rainwulf  Australia
Just built one of these little buggers, assembling the power supply tomorrow.
Its going to be the bass amp for my computer amp. (5xLM3875) and this Class D module.
Got a 2x10inch sealed sub enclosure already built (4ohms total). I expect lots of boom
I am not using the speaker protected for this module, but making one using arduino. It will also control soft on, remote on / auto power on/off.
Old 10th June 2013, 09:52 AM   #20
An interesting part of the reference design is its scalability. The reference design documents discuss in detail how the same schematic and PCB can be used to build a 25W, 60W, 125W or 250W (into 8ohm) amplifier. The principal difference is the rail voltage (from 2x25V to 2x70V), which requires right power FETs and some other minor adjustments. This means that the SiliconChip design can easily scale up or down as well.
This is true. You just have to change a few resistors and zener diodes to get the different operating voltages.
"The Classic-D" - New Class-D Amp from Silicon ChipHide this!Advertise here!
Building "The Wire AMP" Class A/AB Power Amplifier" wirewiggler Solid State 13 24th January 2015 12:22 PM
silicon chip magazine 15w class a amp jamesfeline Solid State 24 24th May 2007 12:01 PM
"classic" amp and begginners problems (pcb wiring, component values) adi81bv Solid State 15 17th April 2007 09:50 AM
where to get transformer for "classic" GainClone? SygnusX1 Chip Amps 5 14th February 2005 01:46 AM
Copyright ©1999-2017 diyAudio
