| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I am looking for a low profile toroidal transformer. Searched through the net and it seems I will have to make it custom made as no one sells a transformer with my requirements.
It would be a simple transformer for an audio amplifier application with 300VA from 230V to 2x25V. The only special requirement for the transformer is the max height that could not be more than 38 millimeters / 1.5". Of course I did a search here before I posted my question and saw someone mentioned Toroidy. Already asked him but unfortunately he is not able to make that custom transformer. Do you have any idea where should I try to make that custom made? |
#2 |
Can you use two 150 VA transformers instead? One for the "plus" supply and one for the "minus" supply?
The power handling capability of a transformer is proportional to the cross-sectional area of the transformer core. The actual core area depends on the core material and such, but there isn't a whole lot of flexibility there. It sounds like you're up against the laws of physics. Let me tell you from experience ... physics always wins! ![]() ~Tom
21st Century Maida Regulator, Universal Filament Regulator, 300B Driver PCBs, and more... Neurochrome : : Audio - http://www.neurochrome.com/audio - Engineering : : Done : : Right |
#3 |
I see no reason why I could not use two 150 VA transformers.
The only problem I could think of is the size that two transformers require two times the space required by one. I will figure this out when I found a suitable transformer with its outside diameter specified.Anyway, I do not want to go against the laws of physics, I am just thinking, planning and asking - fool questions sometimes .
#4 |
@tomchr, do you know a place where I could buy or ask them to make a 150VA transformer for that height?
Checked again various sites selling transformers but in the desired power range (150VA) none of them sell a transformer with the maximum height I am looking for. |
#5 |
Toroidy.pl make excellent transformers and I would imagine could give good advise as to whether its doable in that height.I seem to remember Naim used big VA transformers but they always seemed relatively low profile but with a big diameter.
#6 |
Asked Toroidy again with the new idea of using 2x150VA transformers.
#7 |
Two of these?
Transformateurs torique - Transformateur torique 160VA 2x24V 130x30mm according to the data? /U. |
#8 |
#9 |
@Nisbeth: that is a good idea to use two separate transformers. I have no idea how this does not come into my mind.
@mickeymoose: this is also a nice option, I will ask them for pricing. |
| Low-Profile Torodial Traffo | redjr | Power Supplies | 6 | 20th August 2012 02:15 PM |
| Low Profile Six Channel Amp | The Saint | Aussie Amplifiers | 14 | 16th January 2012 07:51 PM |
| Looking for some low profile conical feet? | audi0 | Construction Tips | 0 | 3rd December 2010 05:04 AM |
| Low Profile Power Transformer Help | dsavitsk | Tubes / Valves | 5 | 10th March 2007 11:35 AM |
| What woofer for low profile HT sub? | xcortes | Subwoofers | 10 | 29th October 2005 03:54 PM |
