| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Which are the lowest noise Zener Diodes, either SMD or through hole, which are in current production, regardless of price?
#2 |
Temp compensated ones like lm329. There are better ones but although you say regardless of price I doubt you want to fork out 60 to 70 dollars for a single part, these are used in space exploration equipment and satelites. Read linear technology application AN82F, very good info on there. You could also make yourself one, just combine a regular zener with a diode.
#3 |
I don't know, but I do know that you should use a voltage well below 5 V if you want low noise, like 3.9 V or less. Higher voltage "zeners" actually have avalanche rather than Zener breakthrough, which causes much more noise.
#4 | |
Indeed, $60-70 a piece I cannot afford (since I need quite a few of those). How do I combine a regular diode with a Zener to lower its' noise? |
#5 |
Theoretically the lowest noise Zeners are for about 8.2V
Also, here is some list I fond in the Net: CMHZ4099: 6.8 V, Low Noise Zener Diode CMHZ4100: 7.5 V, Low Noise Zener Diode CMHZ4101: 8.2 V, Low Noise Zener Diode CMHZ4102: 8.7 V, Low Noise Zener Diode CMHZ4103: 9.1 V, Low Noise Zener Diode CMHZ4104: 10 V, Low Noise Zener Diode CMHZ4105: 11 V, Low Noise Zener Diode CMHZ4106: 12 V, Low Noise Zener Diode CMHZ4107: 13 V, Low Noise Zener Diode CMHZ4108: 14 V, Low Noise Zener Diode CMHZ4109: 15 V, Low Noise Zener Diode CMHZ4110: 16 V, Low Noise Zener Diode CMHZ4111: 17 V, Low Noise Zener Diode CMHZ4112: 18 V, Low Noise Zener Diode CMHZ4113: 19 V, Low Noise Zener Diode CMHZ4114: 20 V, Low Noise Zener Diode CMHZ4115: 22 V, Low Noise Zener Diode CMHZ4116: 24 V, Low Noise Zener Diode CMHZ4117: 25 V, Low Noise Zener Diode CMHZ4118: 27 V, Low Noise Zener Diode CMHZ4119: 28 V, Low Noise Zener Diode CMHZ4120: 30 V, Low Noise Zener Diode CMHZ4121: 33 V, Low Noise Zener Diode CMHZ4122: 36 V, Low Noise Zener Diode CMHZ4123: 39 V, Low Noise Zener Diode CMHZ4124: 43 V, Low Noise Zener Diode CMHZ4125: 47 V, Low Noise Zener Diode CMHZ4614: 1.8 V, Low Noise Zener Diode CMHZ4615: 2 V, Low Noise Zener Diode CMHZ4616: 2.2 V, Low Noise Zener Diode CMHZ4617: 2.4 V, Low Noise Zener Diode CMHZ4618: 2.7 V, Low Noise Zener Diode CMHZ4619: 3 V, Low Noise Zener Diode CMHZ4620: 3.3 V, Low Noise Zener Diode CMHZ4621: 3.6 V, Low Noise Zener Diode CMHZ4622: 3.9 V, Low Noise Zener Diode CMHZ4623: 4.3 V, Low Noise Zener Diode CMHZ4624: 4.7 V, Low Noise Zener Diode CMHZ4625: 5.1 V, Low Noise Zener Diode CMHZ4626: 5.6 V, Low Noise Zener Diode CMHZ4627: 6.2 V, Low Noise Zener Diode And here are Soviet diode-compensated Zeners for 9V, $3/dozen: D818G USSR Zener Diodes Lot of 12 | eBay
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#6 | |
Best Zeners are 6.2V, which sits on the cusp of Zener and avalanche. Forward biased red LEDs are even quieter.
If there's a sucker born every minute, where do the rest of them come from? |
#7 |
Thanks, all.
#8 |
Parallelling cheaper devices is the obvious answer if noise is really an issue. Theoretically 2 devices drop noise by 3dB, 4 by 6dB, 8 by 9dB etc, but practically its never that simple and the point of no real benefit reached for extra devices are 2 devices to about 6 devices usually. (Might be a bigger number with devices not designed for low noise, but that is pointless, you want cheap low noise devices in the first place.) rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow Last edited by sreten; 29th October 2012 at 11:53 PM. |
#9 |
Would a TL431 be lower noise than a zener. I have read that the ones from ONSEMI are the lowest noise of the various mfgs.
#10 |
I thought 431 were a lot noisier.
| Some noise measurements for LEDs and zener diodes | Christer | Parts | 127 | 25th November 2011 11:47 PM |
| 15V zener diodes | mantisory | Vendor's Bazaar | 0 | 16th November 2007 11:55 PM |
| very ignorant question on zener diodes | jarthel | Parts | 1 | 13th October 2006 01:17 PM |
| Bride of ZEN zener diodes | ding | Pass Labs | 21 | 3rd June 2006 04:31 PM |
| [Hybrid Amp] Questions about the use of zener diodes | Johnix | Solid State | 30 | 26th September 2004 08:00 AM |
