Does anyone know where I can get this size of audio capacitor? - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd October 2012, 04:32 PM   #1
Default Does anyone know where I can get this size of audio capacitor?
7500uF or higher, 56V or higher.
Case size diameter 30mm or smaller, Height - not important
to replace 7500 56V caps in my amplifier 20+ years old!
Ta
Old 23rd October 2012, 04:49 PM   #2
kevinkr's Avatar
Somewhere like Farnell or Radiospares would be the places I would start looking.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 23rd October 2012, 04:53 PM   #3
Not here in the UK! needs to be an 'audio' capacitor.
Old 23rd October 2012, 05:12 PM   #4
KatieandDad's Avatar
All these three are 35mm in Diameter, is that close enough ?
Buy 8200uF 63V online from RS Components
If you go down to 6800uF 63V you can get them at 25mm Diameter.
http://uk.rs-online.com/web/p/alumin...itors/7395386/
Bearing in mind the huge tolerances of Electrolytic caps, 6800uF may be OK.
Old 23rd October 2012, 05:14 PM   #5
Thanks anyway but needs to be 30mm or less, as otherwise they won't fit
Old 23rd October 2012, 08:07 PM   #6
It's ok, found some!
Old 24th October 2012, 09:31 PM   #7
xjr100 is offline xjr100  Europe
Ta
Where they used?
Mundorf have MLGO63-10000uF (63V), they sized d=30mm and height =50mm: Electrolytic capacitor Mundorf MLytic AG glue on 10000 uF 63VDC 125C 2pin - Fidelity Components Shop
But check specifications if they can provide current you need.
Auricap XO, Mundorf, Jantzen capacitors, coils, MSolder, terminals, DH-Labs interconnect & speaker cables, internal wiring for DIY & upgrades are here: www.audiohobby.eu
Old 24th October 2012, 11:20 PM   #8
Originally Posted by xjr100 View Post
Where they used?
Thanks anyway but after a long search I finally found some. They're for a kenwood KA-4020 Amp.
Cheers
bypass capacitor size BigE Solid State 0 4th July 2011 05:44 PM
What size capacitor I use for a 2A3 or 300B cathode bypass? sgerus Tubes / Valves 20 4th March 2008 02:18 PM
big size nichicon muse capacitor Pocoyo Parts 2 27th April 2007 11:47 PM
Capacitor Physical size otherside Power Supplies 6 15th July 2006 08:46 PM
Capacitor Size Opinions audiopro Solid State 21 9th June 2004 11:07 AM
Copyright 1999-2017 diyAudio
