Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th October 2003, 07:41 PM   #11
audioPT is offline audioPT  Portugal
Originally posted by Christer
MM or MC??
Moving Coil
Originally posted by jwb
Hey peter, how come you always have so many pictures of Levinson equip?
Goto here:
http://www.marklevinson.com/image_library/index.asp
If you ave aDSL or a fast connection, see the quality of the large photos
Old 31st October 2003, 06:16 PM   #12
jcarr is offline jcarr  United States
Has anyone perchance used the AD797 with TL431-based shunt regulation (either with or with auxiliary current booster)?
I've previously used the 797 mainly with series IC regulators (for instance, 317/337, LT1086/LT833) without noting any stability or sonic problems (assuredly with local capacitive bypassing at the load), and now I would like to try IC-based shunt regulation.
However, studying the data sheet of the 431 reveals that the output impedance rises steadily above 50kHz until it hits about 13~14 ohms in the 1~5MHz region. I am interested in knowing if this impedance will pose problems for the AD797, and likewise if local capacitive bypasses to ground at the 797's power supply pins will be sufficient to keep it stable and well-mannered.
Any experience or thoughts will be appreciated.
regards, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 31st October 2003, 10:07 PM   #13
planet10's Avatar
Originally posted by audioPT
is in a Tecnhics SL1210MKII
Your limiting factor in this rig will end up being the DD TT.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
AD797, how to make the best of it nelsonvandal Solid State 56 22nd October 2008 02:08 PM
Tips for AD797 ?? redrabbit Everything Else 11 2nd October 2008 05:55 PM
AD797 guts aparatusonitus Solid State 3 21st March 2008 06:02 PM
WTT: MJ15003/4 for AD797 Andypairo Swap Meet 0 5th February 2007 08:04 PM
Where can I get an AD797 Op-Amp? xanduy Swap Meet 4 29th March 2004 08:06 AM
Page generated in 0.07549 seconds (83.45% PHP - 16.55% MySQL) with 11 queries
