Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Attenuator terminal for speakers
Old 9th October 2012, 05:37 PM   #1
flancfuster is offline flancfuster  Romania
Default Attenuator terminal for speakers
Does anyone know where to find similar attenuator terminal for speakers?
Thanks.
Old 9th October 2012, 05:50 PM   #2
Mooly's Avatar
Those kind of things look totally manufactuer specific. I've never come across anything like that in all the years of looking at parts catalogues etc. Easy to make one though
Old 9th October 2012, 06:02 PM   #3
Thank you for reply.
I was thinking also to build it myself but I need quality connectors. Do you have something in mind?
Old 9th October 2012, 07:39 PM   #4
Mooly's Avatar
Only to use decent terminations of some sort. These kind of things are really set once and forgotton rather than constantly altered.
If I was doing it myself I might even favour a small "open" PCB with the print side showing and use solder bridges for the connections. Could be made very small and guaranteed perfect connectivity with no degradation.
Old 9th October 2012, 08:19 PM   #5
xjr100 is offline xjr100  Europe
Just another set of speaker terminals, which you will use in your speakers.
And use jumpers to short them.
Auricap XO, Mundorf, Jantzen capacitors, coils, MSolder, terminals, DH-Labs interconnect & speaker cables, internal wiring for DIY & upgrades are here: www.audiohobby.eu
Old 10th October 2012, 12:26 AM   #6
Enzo is offline Enzo  United States
How about using a dual banana male plug, wired as a shunt. Then make a pattern of five banana female single jacks, similar to the pattern of your example. Plug the banana shunt from the common to whichever option you desire. COme to think of it, they make special dual banana plugs that are already wired shunt internally.
For many years, in guitar amps, Marshall used an impedance selector socket with a moveable jumper plug that worked exactly as your example does, though it looked different. They later replaced it with a rotary switch.
Unless the cosmetics are important to you, certainly a rotary switch ought to work.
Old 10th October 2012, 11:05 AM   #7
Thank you all for comments.
Looks like I have to build it myself.
Regards.
Attenuator terminal for speakersHide this!Advertise here!
3 terminal regulator with 3 terminal shunt reference BWRX Power Supplies 11 17th January 2013 10:08 AM
Speakers Has No Terminal Links. girishkukadia Multi-Way 11 24th March 2012 04:24 PM
Which terminal is postive ? Jan Dupont Multi-Way 23 14th March 2007 09:35 PM
4 terminal mosfets rtarbell Parts 0 7th November 2006 04:28 PM
