Is high, or low, Hfe better for a CCS? Is high, or low, Hfe better for a CCS? - Page 3 - diyAudio
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th October 2012, 07:22 PM   #21
Elvee is offline Elvee  Belgium
Elvee's Avatar
Originally Posted by SY View Post
Yes, but a high hfe and (relatively) high emitter resistance totally overwhelm even the highest collector resistances (1/hoe, basically).
No, and that is clearly shown in the graphs I posted: basically what counts is the ratio of the (external) emitter resistance to the dynamic emitter resistance (~=26/Ie).
The Hfe is only a higher order factor and plays a minor role
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 9th October 2012, 09:03 PM   #22
counter culture is offline counter culture  United States
Interesting how what at first looks obvious turns out not to be, as is so often the case in electronics.
Old 9th October 2012, 09:27 PM   #23
DF96 is offline DF96  England
Yes. I have certainly learnt something. Snag is, within a few months I will probably have forgotten it!
Old 9th October 2012, 09:48 PM   #24
On Hiatus
SY's Avatar
I'll admit to being somewhat incompetent with sims, so it's not so clear to me; could you explain your graphs (e.g., what are they measuring and how, which curve corresponds to which hfe...)? I'm particularly confused by how much the resistances vary with very small increments of frequency.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 10th October 2012, 01:05 AM   #25
magnoman is offline magnoman  United States
I understand that when cascoding the transistors then there is a beta multiplication of the output resistance.
With the simple current source as shown (with emitter resistors) I have trouble understanding why the output resistance would increase with decreasing beta. It would seem to me the opposite effect and mostly only with low beta.
From a transistor physics point of view (well outside my aptitude) I would think that minimizing the base width modutation from the CB would require a sacrifice in the the b-e doping concentrations and thus a lower beta may be associated with very high early voltage transistors (though this is seperate from just the circuit analysis of the simple current source and only varying the beta).
-Antonio
Old 10th October 2012, 04:45 AM   #26
Elvee
Just zoomed in on your plots and now at least understand what your saying.
That is just increasing beta increases Ro slightly as expected, but that once the full model is reflective of the higher beta parts Ro decreases.
Do your models have more than just differences in VAF to account for this?
-Antonio
Old 10th October 2012, 01:50 PM   #27
Elvee's Avatar
Simulators are good at plotting things, and even when all you really need is a single value, it is simpler to make a bogus frequency sweep, or something like that.
Here, I have chosen to analyze the behavior of the output impedance over the 10Hz to 20Hz interval: it is so small that no discernable change happens, this explains the flat lines (the solid ones, the dotted ones are the phase and are of no interest).
The first three (red, yellow and cyan traces) are "actual" transistors, BC 847A, B, and C. The suffix letter indicates the gain class: http://hep.fi.infn.it/PAMELA/pdf/bc847.pdf
A: typ. 180, 110 to 220
B: typ. 290, 200 to 450
C: typ. 520, 420 to 800
We see that despite the increase in Hfe, the output impedance decreases in large proportions: down to 1.9 Meg for the C.
This means that the effect of h22 increase with Hfe is overwhelming over the value of Hfe itself (the models come from NXP and are quite accurate).
I have then investigated the effect of a "pure" Hfe increase, ie I have tweaked the BF parameter in the BC847A model, without changing the other parameters that are normally associated with a higher Hfe.
There we see an increase in impedance (magenta and grey traces), but a very modest one.
Here are the models:
.model BC847A NPN(IS=9.677E-15 NF=0.9922 ISE=5.44E-15 NE=2 BF=182.1 IKF=0.14 VAF=143.8 NR=0.9935 ISC=5.236E-12 NC=1.53 BR=7.004 IKR=0.06 VAR=31.15 RB=10 IRB=5.00E-06 RBM=4 RE=0.78 RC=0.656 XTB=0 EG=1.11 XTI=3 CJE=1.443E-11 VJE=0.733 MJE=0.3514 TF=6.04E-10 XTF=8.94 VTF=3.78 ITF=0.2711 PTF=0 CJC=3.287E-12 VJC=0.5444 MJC=0.3954 XCJC=0.6193 TR=0.00000011 CJS=0 VJS=0.75 MJS=0.333 FC=0.789 Vceo=45 Icrating=100m mfg=Philips)
.model BC847B NPN(IS=1.822E-14 NF=0.9932 ISE=2.894E-16 NE=1.4 BF=324.4 IKF=0.109 VAF=82 NR=0.9931 ISC=9.982E-12 NC=1.763 BR=8.29 IKR=0.09 VAR=17.9 RB=10 IRB=5.00E-06 RBM=5 RE=0.649 RC=0.7014 XTB=0 EG=1.11 XTI=3 CJE=1.244E-11 VJE=0.7579 MJE=0.3656 TF=4.908E-10 XTF=9.51 VTF=2.927 ITF=0.3131 PTF=0 CJC=3.347E-12 VJC=0.5463 MJC=0.391 XCJC=0.6193 TR=9.00E-08 CJS=0 VJS=0.75 MJS=0.333 FC=0.979 Vceo=45 Icrating=100m mfg=Philips)
.model BC847C NPN(IS=2.375E-14 NF=0.9925 ISE=5.16E-16 NE=1.3 BF=524.9 IKF=0.09 VAF=49.77 NR=0.9931 ISC=7.064E-12 NC=1.78 BR=10.04 IKR=0.132 VAR=16 RB=10 IRB=5.00E-06 RBM=5 RE=0.653 RC=0.78 XTB=0 EG=1.11 XTI=3 CJE=1.132E-11 VJE=0.7685 MJE=0.3733 TF=4.258E-10 XTF=6.319 VTF=6.4 ITF=0.1845 PTF=0 CJC=3.379E-12 VJC=0.5444 MJC=0.3968 XCJC=0.6193 TR=0.000000095 CJS=0 VJS=0.75 MJS=0.333 FC=0.999 Vceo=45 Icrating=100m mfg=Philips)
You can see that practically all parameters are affected by the change in doping, not only VAF.
Old 10th October 2012, 02:15 PM   #28
On Hiatus
SY's Avatar
Great, many thanks for clarifying!
Old 10th October 2012, 02:38 PM   #29
stinius is offline stinius
And a disaster if they are used wrong.
Could you please post a readable plot with white background?
S
Old 15th October 2012, 07:30 PM   #30
So for a Wilson (or cascode) the final current stage transistor should be a "C" version, not sure about the other 2 transistors.
-Tony
Is high, or low, Hfe better for a CCS?Hide this!Advertise here!
Questions about Transistors with high beta (hfe) up to 3000 without Darl.-Topology tiefbassuebertr Solid State 37 16th December 2011 12:57 PM
How to measure high current Hfe? nonsub Solid State 10 27th January 2010 12:11 PM
seeking: 1.5A+ low noise, high hFE transistor riotubes Parts 11 22nd October 2008 12:11 PM
Searching for high hfe, low noise and cob PNP BJT roender Solid State 34 30th March 2007 08:31 AM
Copyright ©1999-2017 diyAudio
