Is high, or low, Hfe better for a CCS? - Page 4 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th October 2012, 09:34 PM   #31
jcx is offline jcx  United States
Default topology trumps
still would add another Q before worrying about which Q parameters are "best"
note the factor of 100x in front of the 3 Q yellow waveform plot
Old 15th October 2012, 10:11 PM   #32
Now wheres the fun in that?
Well okay but its a different kind of fun.
-Antonio
Old 11th October 2014, 08:53 PM   #33
pwan is offline pwan  United Kingdom
Sorry for bringing this old thread up again.
With my limited knowledge, not sure whether or my understanding is correct. So .... For CCS transistor (8-10ma idle current), the lower hfe the better ?
Thanks in advance for clarification.
Old 11th October 2014, 09:13 PM   #34
Elvee is offline Elvee  Belgium
Elvee's Avatar
Things are never simple and clear-cut: if you talk about a robustly dimensioned CCS, lower Hfe is in principle better, but in shady areas anything can happen
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 11th October 2014, 09:26 PM   #35
Thank you Elvee.
That should be a good news. In my case, I mean the CCS for VAS stage ( 10ma with BC546C as controlling resistor). The VAS is PNP. Its complementary (NPN) for CCS comes in much lower hfe grade. To get the NPN ones with the same hfe grade as PNP is x10 times more expensive.
Questions about Transistors with high beta (hfe) up to 3000 without Darl.-Topology tiefbassuebertr Solid State 37 16th December 2011 01:57 PM
How to measure high current Hfe? nonsub Solid State 10 27th January 2010 01:11 PM
seeking: 1.5A+ low noise, high hFE transistor riotubes Parts 11 22nd October 2008 01:11 PM
Searching for high hfe, low noise and cob PNP BJT roender Solid State 34 30th March 2007 09:31 AM
Copyright ©1999-2017 diyAudio
