Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
unpotting, solvent, melting agent, removal agent, for transistor or IC cases??
Old 28th October 2012, 12:09 AM   #31
DaveG is offline DaveG  United States
I still had the parts taped to a piece of paper, so here are a few photos. These were taken hand held with an old 4MP Sony shooting through the eye piece of a 20 power loupe, shimmed up with business cards to get the focal distance right. So it popped apart quite clean when slightly over heated.
Old 28th October 2012, 02:38 AM   #32
bear is offline bear
expert in tautology
bear's Avatar
Jitter, I don't know exactly. But the more certain that I am that these are not Toshiba the stronger my response will be... in various regards.
One supplier has agreed to take back one batch back, it remains to be seen if I will get anything back after I send it overseas.
I had ordered from a few suppliers figuring that they all wouldn't have bogus parts... ha ha.
DaveG, looks good. I've tried to crack a few, the results were not as good as yours. I may try some external heat and then a crack... what I saw through my stereo inspection microscope was a square blob that did not reveal any discernible surface characteristics that could be identified as one type of die layout or another... reasonably confounding in fact.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 2nd November 2012, 06:47 PM   #33
expert in tautology
bear's Avatar
Here's the problem with the crack in the vise to open - the die surface is shattered. Apparently the epoxy is tenacious.
This one was with some significant heating first... propane torch... then a crack.
maybe next time I will apply excess heat to the pins, but I suspect that will pull the die off the flat copper area inside the package.
_-_-
_-_-bear
Old 16th November 2012, 04:14 PM   #34
PedroDaGr8 is offline PedroDaGr8  United States
PedroDaGr8's Avatar
Well, I have a TO-92 case that so far I have soaked in room temp (RT) methanol, DMSO, Toluene, Chloroform, Acetone, DMF, Octadecene and water (because why not). Nothing so far has shown any signs of working. I'm debating boiling DMSO, if that doesn't work then I'm thinking agua regia next
Old 16th November 2012, 06:02 PM   #35
expert in tautology
bear's Avatar
A member emailed me with pix showing that the "2SJ74" being sold are re-badged Fairchild parts. On some of his batch the Fairchild markings were not fully removed! Quite obvious.
Bogus parts.
Arrrgh!
_-_-bear
_-_-bear
Old 16th November 2012, 06:05 PM   #36
expert in tautology
bear's Avatar
Default bogus 2SJ74 from asia
Here's what my curve tracer showed.
Identical settings, btw...
the curvy ones are the bogus parts.
_-_-bear
unpotting, solvent, melting agent, removal agent, for transistor or IC cases??Hide this!Advertise here!
Agent needed from OKC or Dallas area who is going to Dayton, OH 7/14 jmillerdoc Swap Meet 0 19th June 2012 04:38 AM
IKEA, Orlando, FL; need purchasing agent Ed LaFontaine Swap Meet 18 30th March 2012 04:52 PM
What solvent for best removal of solder flux? space Everything Else 10 18th April 2007 07:57 AM
Chemical Stripping Agent for Magnetic Wire mbcouple Parts 8 20th January 2005 10:44 AM
Copyright ©1999-2017 diyAudio
