Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Looking for silver digital coax
Old 4th October 2012, 09:16 AM   #61
tvrgeek is offline tvrgeek  United States
Silver coax. I have to suggest you have been sold a bucket of goods. Sit back and think about the path your music has gone through before yo got it. If you were building some scientific instrument where you were the source of some ultra sensitive quantum sensor, maybe I could believe it.
Your amplifier has metal oxide resistors, copper traces and aluminum traces inside the chips.
Please take cbdb's comment to heart. It is well intentioned. We don't mind pushing the limits, but spend you effort and money on things that matter.
Old 4th October 2012, 09:21 AM   #62
On Hiatus
SY's Avatar
Originally Posted by s3tup View Post
cbdb, D-75's slew rate seems a bit faster. Does it mean something to you?
Whether it means something to you or cbdb is irrelevant. The "slew rate" (and I think you're misusing the term, I suspect you mean "rise time") doesn't matter to the receiver unless it's so slow that the transition gets "displaced." The waves would look more like triangles in that case- never actually seen one like that. spdif signals can look pretty poor to the human eye without affecting the receiver- one of the worst I've seen was a horribly ringy USB-spdif converter (Hiface) which nonetheless worked fine.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 4th October 2012, 09:41 AM   #63
s3tup is offline s3tup
s3tup's Avatar
My mistake, "rise time" is the correct term.
It doesn't matter for the receiver for it's operation (if operation means keeping the PLL locked and data transmission uninterrupted).
The PLL gets squeaked by the jitter, FIFO attenuates the jitter only at HF, and LF jitter just passes thru. Everything is suboptimal and rather transparent from interface jitter...
Minimizing the rise time = minimizing the aperture uncertainty time of the receiver, which leads us to less "captured" noise at the decision point, resulting in less jitter.
Fast driver, proper transmission line is always better. No need to make it silver and gold-covered - just a good BNCs, cable and everything impedance-matched in 75ohm (for compatibility).
Or just thrash everything, throw a clock at the DAC, and sync the transport to it. It costs less than the "awesome audiophile interconnects".
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 4th October 2012, 10:18 AM   #64
marce is offline marce  United Kingdom
Merlin, as I said Imeant no disrespect
The scope shots dont have enough resolution to detrermine rise time change,
and even then a slight decreasing of the rise time (within certain parameters)
would not be detrimental to the signal but probably beneficial.
As to the rest, as stated its a digital signal with a bit of overshoot and ringing
nothing to worry about.
Heres some links to some (if not thee) top guys for digital signal integrity.
Signal Consulting, Inc. - Dr. Howard Johnson
beTheSignal.com
Speeding Edge consultants specialize in high-speed PCB and system design disciplines
Part of the Hiface problem with ringing was a ridiculasly fast rise time for the signal frequency, increasing the high frequency harmonic content of the signal and causing more problems, than it solved.
Old 4th October 2012, 10:27 AM   #65
DF96 is online now DF96  England
A few metres of cable causes a little high frequency jitter, which is removed by the receiver PLL - that is what it is designed to do. Low frequency jitter comes from the CD player crystal oscillator, and neither the cable nor the PLL can do anything about that. Too fast a rise time creates problems, as would too slow a rise time.
All these people obsessing about silver cables etc. (even with RCAs!!) would do better to learn about data slicers, PLLs and low noise crystal oscillators. If any improvement is needed, which is unclear to me, that is where the improvement would lie. It seems standard 'audiophool' logic to concentrate on the one thing which makes no difference (the cable), presumably on the grounds that it is easy to show a meaningless change on an oscilloscope trace.
Old 4th October 2012, 12:54 PM   #66
Some real life digital signals that work perfectly, for your perusal,and to illustrate that the digital wave has no correclation (within limits) to any further stages in its journey.
Old 4th October 2012, 03:36 PM   #67
davidsrsb is offline davidsrsb  Malaysia
Slow rise times cause very little jitter so long as:
1) The receiver slicing point is accurately at the midpoint
2) Low frequency response is good enough to avoid too much sag on a long sequence of "1"s or "0"s
The cable has nothing to do with either of these
Old 4th October 2012, 05:12 PM   #68
RJM1 is offline RJM1  United States
I had a friend once who said " Anything under 1 MHZ is considered DC. ". After dealing with C band microwave (4300 MHZ) (Radio Altimeters) for 8 years; I believe him.
In my opinion it is best to use the highest impedance (lowest capacitance) cable if you are going to use coax for audio purposes.
Old 4th October 2012, 05:43 PM   #69
Maybe something like this (13pF-ft).
http://www.gore.com/MungoBlobs/584/377/CXN1458c.pdf
Old 4th October 2012, 07:02 PM   #70
On Hiatus
SY's Avatar
This is digital transmission, not analog audio. That sort of cable may be fine for preamp-to-power amp, but the characteristic impedance is wrong for spdif (needs to be 75 ohms).
Looking for silver digital coaxHide this!Advertise here!
Northwest Analogue Gold Plated Pure Silver Digital Coax dominic harper Vendor's Bazaar 0 8th November 2011 09:12 PM
FS: Hawthorneaudio Silver IRIS 15" coax drivers UK barackuda Swap Meet 6 28th August 2008 09:46 PM
Digital Coax to 5.1 Analog? ak_47_boy Digital Source 9 16th November 2006 02:24 PM
DIY Digital Coax ralph-bway Everything Else 1 9th July 2004 07:03 PM
Coax digital out to computer hoongern Digital Source 3 27th February 2004 09:16 PM
