Looking for silver digital coax - Page 6 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 3rd October 2012, 06:59 PM   #51
s3tup's Avatar
Merlin, how do you drive such low impedances?
Opamps are ruled out. Most of the buffers too. I'm aware of only one buffer which could drive such load, but it cost quite a lot for an IC, and is out of production. TO-3 cased LH0063...
Alternatives...
- LME49600
- Opamp-wrapped BUF634/AD815...
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 3rd October 2012, 07:20 PM   #52
Art M is offline Art M  United States
Default Baffled
Originally Posted by xjr100 View Post
If there is something noticable to ears, it cold be seen on measurement equipment.
I enjoy learning, exactly what is it that you are measuring and how do I interpret
the Scope images ?
Old 3rd October 2012, 07:41 PM   #53
merlin el mago's Avatar
I use Erno Borbely stuff I/V DAC, lineamp/headphone amp and 75W RMS monobolocks amps. I'm using balanced with two separate PSU and two stereo preamps in two chassis (one for 2 PSU and the other chassis for the 2 preamp)
Preamp topology
"The input JFET-Cascode, consisting of Q1-Q2-Q3 and Q4 are operated at 2 mA. Q1 and Q2 have to be matched to 10% of Idss. The second stage, consisting of JFETs Q6-Q9 and MOSFETs Q7-Q8, are operating at just below 10mA. Q6 and Q9 have to be selected for Idss>10mA. Note that this also provides matching between the N- and P-channel JFET. The output devices: Q10-Q11 are Hitachi TO-220 MOSFETs. They are operating at approx. 70mA; proper heat sinking is therefore mandatory.
Q5 is a JFET-input servo amplifier, providing tracking of the output offset to less than 1mV. The RC-networks of R10-C6 and R11-C7 filter out all AC signals over 1 Hz. The servo is therefore only operational at less than 1 Hz, and should not affect the sound of the amplifier. Nevertheless, if you feel that it does, donít hesitate to try different opamps for this. D1 and D2 are IC shunt regulators, supplying Q5 with +-10 Volt."
Old 3rd October 2012, 07:52 PM   #54
Alternatives...
- LME49600
Borbely 116 lineamp schematic Click the image to open in full size.
Old 3rd October 2012, 08:08 PM   #55
DF96 is offline DF96  England
OK, so you have to use a headphone amp to drive an interconnect.
Old 3rd October 2012, 08:12 PM   #56
Is a line amp / headphone amp, I use the resistors for the power amp not for the headphones....
Old 3rd October 2012, 08:35 PM   #57
Q. What is a line/headphone amp?
A. A headphone amp used, for some peculiar reason, to drive a line.
Old 3rd October 2012, 09:16 PM   #58
cbdb is offline cbdb  Canada
Here is the picture of Dune HD Base 3.0 media player SPDIF out with cheap cable (7€) vs DH-Labs D-75:
And what exactly are you seeing that will make any difference? Anything on the scope above/below threshold (like all the garbage on the top and bottom) makes NO difference to the sound. Please learn about digital electronics.
Old 3rd October 2012, 10:13 PM   #59
s3tup's Avatar
cbdb, D-75's slew rate seems a bit faster. Does it mean something to you?
Oh, headphone amps... Yep, that's what they are - a good line drivers.
Old 4th October 2012, 10:04 AM   #60
Northwest Analogue Gold Plated Pure Silver Digital Coax dominic harper Vendor's Bazaar 0 8th November 2011 10:12 PM
FS: Hawthorneaudio Silver IRIS 15" coax drivers UK barackuda Swap Meet 6 28th August 2008 10:46 PM
Digital Coax to 5.1 Analog? ak_47_boy Digital Source 9 16th November 2006 03:24 PM
DIY Digital Coax ralph-bway Everything Else 1 9th July 2004 08:03 PM
Coax digital out to computer hoongern Digital Source 3 27th February 2004 10:16 PM
Copyright ©1999-2017 diyAudio
