| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#21 |
It is common for high quality coax to use a silver plated steel centre conductor -steel is stronger. The consequence is higher than expected loss at low frequencies when the skin effect reduces and the poor conductivity of steel becomes important. Stranded centre conductor coax is intended for flexibility
#22 |
RF uses parasitic capaciance and quite often the planet....we are talking about digital signal transmission (SPDIF I imagine) the signal requires a return path full stop. It aint gonna return through the air!
Low frequenicy audio analogue will be using the earth connections. The shield provides the return path, it dosn't help IT IS the return conductor for a standard co-ax cable. Currents that return through air are quite noticable, they have a tendency to ionise and spark some what. Of course then we come to the SWITCH, you may of heard of these usefull little components, if electrical current worked the way you are thinking these devices would be totaly redundant. Just remember we are NOT discussing RF but DIGITAL signal transmission. |
#23 | |
Audio signals can use ground leads as a signal return if there is not a dedicated return conductor. Different issue. |
#24 | |
Makes no sense to use expensive coax cable unless you are using it for RF purposes. Standard RG-6/U is more than sufficient for your digital transmission applications, especially if you are using "RCA" type connector, which is not a controlled impedance connector design = garbage for most for RF purposes. Regards Rick |
#25 | |
MSRP is 90$ for 1.5m factory terminated cable. I really like those RCAs: http://www.silversonic.com/docs/prod...structions.pdf
Auricap XO, Mundorf capacitors, coils, MSolder, terminals, DH-Labs interconnect & speaker cables, internal wiring for DIY & upgrades are here: www.audiohobby.eu |
#26 |
Here is the picture of Dune HD Base 3.0 media player SPDIF out with cheap cable (7€) vs DH-Labs D-75:
#27 | |
edit: Never mind, I see this is stuff you're selling.
If there's a sucker born every minute, where do the rest of them come from? |
#28 |
Not only
I use it in my system too For topicstarter I'm usless from commercial point of view - I'm in EU and he can get this stuff from US without high shipping costs. D-75 cable also availabe as "bulk" for DIY. That is exactly what I do - non of my cables (except HDMIs and Optical) bought ad "factory terminated". Saves about 1/2 of the price. The story of those osciloscope pictures was that after replacing digital cable to D-75 from Dune to DAC I did not beleived to my ears that this kind improvement could be with digital cable and decided to check. If there is something noticable to ears, it cold be seen on measurement equipment.
#29 |
Back into the world of Salvador Dali Digital Transmission...
#30 |
Please respect for Dali
| Northwest Analogue Gold Plated Pure Silver Digital Coax | dominic harper | Vendor's Bazaar | 0 | 8th November 2011 09:12 PM |
| FS: Hawthorneaudio Silver IRIS 15" coax drivers UK | barackuda | Swap Meet | 6 | 28th August 2008 09:46 PM |
| Digital Coax to 5.1 Analog? | ak_47_boy | Digital Source | 9 | 16th November 2006 02:24 PM |
| DIY Digital Coax | ralph-bway | Everything Else | 1 | 9th July 2004 07:03 PM |
| Coax digital out to computer | hoongern | Digital Source | 3 | 27th February 2004 09:16 PM |
