Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#21 |
Nice test box
#22 | |
You could check the 3M site, or Textools. Alternately there are Mill-Max pins which could be purposed for this. |
#23 |
#24 |
thanks!!
#25 |
WSJ..... I noticed the device under test in your post #23, marked Nexus.
Just went thru my old parts bin, and found four Philbrick/Nexis PP45U modules. They each have seven leads (+In, -In, +15v, -15v, common, output, and trim) They also have gummed labels on the side indicating Offset trim [16k], +I trim [331M] and -Trim [329M]. (The values in brackets [] vary significantly from one module to the next; these values have been handwritten on the with gummed label.) All four appear to be unused. Can you advise what these are (I'm assuming early Op Amps). Are they worth anything today? I'm old--please tell me they are priceless, so I can retire in style.... ![]() Thanks.... Just curious......... Didn't mean to hijack the thread....(!) |
#26 | |
I worked at Intech in the 70’s, only 43 years ago. We made great discrete op amps, they sold for $150 - $450, at the time gas was 24 cents. Philbrick/Nexis sold similar op amps, so we evaluated the completion, most of ours were better. Your amps may be worth putting on ebay. Do a search for discrete Op Amps and you will find some very good audio Op Amps. The 990 Discrete Op Amp is almost exactly the same circuit as the A148 Intech, my personal favorite. http://www.johnhardyco.com/pdf/990.pdf The balance resistor is a selected single fixed resistor to balance the offset. The amp was made unbalanced to avoid using a pot to balance the amp, in order to keep the cost down. Here are some Intech 10 MHz bandwidth op amps. ![]() ![]() |
Thread | Thread Starter | Forum | Replies | Last Post |
New 6C33 Socket | FullRangeMan | Tubes / Valves | 18 | 3rd June 2011 03:22 PM |
Socket Saver | Kashmire | Tubes / Valves | 2 | 3rd January 2010 01:49 AM |
Which socket for a 5Y3?? | Richard Ellis | Tubes / Valves | 2 | 11th November 2008 04:41 PM |
Help on tube socket | dung0981 | Tubes / Valves | 6 | 5th August 2006 08:31 AM |
what rca socket do you think is best?? | wuffer | Parts | 24 | 25th May 2006 11:35 PM |
New To Site? | Need Help? |
