LM3875 socket - Page 2 - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 29th September 2013, 12:21 PM   #11
I am pretty sure this will end in tears for you.
I would prefer to invest in some de-soldering braid...
Old 29th September 2013, 04:40 PM   #12
WSJ is offline WSJ  United States
WSJ's Avatar
Those sockets are way too small.
Thanks anyhow.
Old 29th September 2013, 05:25 PM   #13
WSJ's Avatar
I use the socket pins for low current test parameters.
I'm designing some Op Amp test fixture adapters for the LM3886 and LM3875. The first adapter is the LM3875.
Test fixture measurements for LM3875, (Data sheet).
TA = 104 F
Vos = 0.128 mV, (10 mV)
Iibin = +90.9 nA, (1 μA)
Iibni = 85.7 nA, (1 μA)
SR = 20 V/μs, (5 μs)
As you can see, the measurements are much better than the data sheet maximum limits.
Old 30th September 2013, 04:35 AM   #14
Datasheet maximums are selected to be good enough for the major customers, while being loose enough for most chips to pass and be FAST to test. Measuring nA currents on a production line is fiddly
Old 1st October 2013, 10:49 AM   #15
I might have missed the explanation in earlier posts - so apologise if I am asking a repeat question. But...
What is it that compels you to want to measure these parameters? Are you planning to use these devices in some unconventional application?
Remember that these parameters will be quite dependent on temperature and to a lesser extent time etc...
Old 2nd October 2013, 06:16 PM   #16
And you will not hear the difference between measured good and measured worse chips.
Old 3rd October 2013, 06:55 PM   #17
WSJ's Avatar
The amplifier is being used as a bipolar current sink. The amplifiers are selected for several parameters to meet the specifications for the application.
Old 3rd October 2013, 08:10 PM   #18
jackinnj's Avatar
I believe National used a staggered ZIF socket in their proto-typing.
Old 3rd October 2013, 08:57 PM   #19
WSJ's Avatar
I found a LME49830 demo board parts list, but no socket was listed.
Do you have a link for the socket?
Old 4th October 2013, 12:59 PM   #20
If this is being used as the power stage of a current sink, you would probably be best off going something a tad more complex. I would consider using a low offset drift, low input offset operational amplifier as the sense element, and use the LM3886 as the power stage.
Alternatively, if you are not running this over a large range of currents, you might want to consider the error that the offset / bias of the LM3886 introduces, and size the current sense element appropriately.
But this is just me.
New 6C33 Socket FullRangeMan Tubes / Valves 18 3rd June 2011 03:22 PM
Socket Saver Kashmire Tubes / Valves 2 3rd January 2010 01:49 AM
Which socket for a 5Y3?? Richard Ellis Tubes / Valves 2 11th November 2008 04:41 PM
Help on tube socket dung0981 Tubes / Valves 6 5th August 2006 08:31 AM
what rca socket do you think is best?? wuffer Parts 24 25th May 2006 11:35 PM
Copyright 1999-2017 diyAudio
