| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi Folks,
Has anyone tried building the hi voltage power supply shown on http://www.glassware.com/tubecircuit...Regulator.html I am trying to make sense of the circuit as i dont think it is very clear... Is it based on a single supply rail ? why is the 5K resistor on the source of the FET and not on the 0v side (i would imagine that the 5v feedback reference would be with respect to 0v).. if someone as the full article, or can nake sense of the circuit, please reply Cheers |
#2 |
diyAudio Moderator Emeritus
Hi Badflier,
Typo I think... Is this the one you meant? http://www.glass-ware.com/tubecircui...Regulator.html |
#3 | |
Banned
A similar circuit is in the Book by Horowitz and Hill, the Art of Electronics, fig 6.51 in my second edition. I believe the chip is powered from the source resistor + drain-source drop.
#4 |
thanks for the reply chaps.. Well i built the circuit on glass-ware and to my amazment it works !!! For the application i'm going to use it for i need atleast 300v @ 6A, yep thats 1800W !! if i assume the load is 50R...
Cant buy FETs with that power so i'll need to cascade a few in parallel i thinks... as anyone tried doing this with FETs ? if so i'd like to get some tips on the best way of wiring them thanks |
| Low Voltage (~16-20V) Tube | tgymartin | Tubes / Valves | 4 | 28th June 2009 08:40 AM |
| tube heater over voltage!please help... | tubo | Tubes / Valves | 6 | 8th April 2009 11:58 AM |
| tube heater voltage, how much is too much? | randytsuch | Tubes / Valves | 26 | 19th August 2008 02:42 AM |
| SS or tube voltage amplifying stages in an amp with tube output? | ray_moth | Tubes / Valves | 14 | 4th July 2007 03:09 AM |
| Tube voltage help | 24kilo | Tubes / Valves | 2 | 11th April 2006 12:35 AM |
| Page generated in 0.08429 seconds (73.42% PHP - 26.58% MySQL) with 10 queries |
