Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
2SK170 which to use gr bl or v? f?
Old 19th September 2012, 11:30 AM   #1
audio mind is offline audio mind  United States
Default 2SK170 which to use gr bl or v? f?
2SK170 which to use gr bl or v? The gr draws the least current the v the most although most designs I have seem to use the bl version any major sound differences between the three?
Does anyone know about a 2SK170BL ADDC: (F) version? No info on the data sheet from Toshiba for the "f'" version. Thanks to anyone with info on these......
Old 19th September 2012, 01:14 PM   #2
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
It might help if you specify what the application is depending on the circuit higher or lower current draw may be desirable.
Sure it might sound better if you use the right one, but it won't be because A BL universally sounds better than a gr, it will be because it is more suitable for that particular circuit, and for a different circuit the gr may be a better choice.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 19th September 2012, 01:43 PM   #3
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Good place to start understanding is with Erno Borbely's articles which appeared in Audio Electronics 5/99. Erno seems to have taken his site down, but the articles appear in several places:
http://ken-gilbert.com/images/pdf/er...y_on_jfets.pdf
There's not an easy answer -- it depends upon the impedance of the following stage and how the device is biased. There's a rule of thumb, however which states they sound best when biased to 70% of Idss.
Old 19th September 2012, 05:30 PM   #4
Thanks for the quick replies. I am using them to try out a few of the the moving magnet phono pres found on the web. I found out ADDC: (F) version apparently is the specific Toshiba batch code for the 2SK170BL. I am not sure if it is any better than non "F" versions.
I think most are using the "BL" version in the phono pre's but it is not usually specified. It is funny even the stop box people seem to like the BL over the GR stating it is smoother less harsh. Guess the high current "V" is harder to come by and maybe not used because of this?
Thanks for the Borbely article link. I scanned it but will read it more closely later on. Interesting.
2SK170 which to use gr bl or v? f?Hide this!Advertise here!
2SK170 BL MC step up amp batty Analogue Source 100 26th January 2018 11:52 AM
Substitute for Toshiba 2SA970 GR or BL? fredlf Parts 13 30th January 2017 09:21 PM
J-Fet & bias ? BL / GR ? Cobra2 Solid State 9 11th January 2012 01:16 PM
Ono Q15, GR or BL rsbay Pass Labs 2 7th May 2008 05:50 AM
Transistor type BL or GR for XOno ? VS Pass Labs 8 9th January 2005 07:11 PM
