Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Help locating C3228 transistor...
Old 17th September 2012, 11:57 PM   #11
audioarsonal is offline audioarsonal
So I have found. But that is not the cas here. I believe the part I am oooking for is in fact KTC3228 which is a KEC brand transistor. But I have found it to be obsolete. Or at least discontinued. So I am looking for NOS C3228 transistors I guess. I am learning as I go. But it seems very in depth. Thanks fo all the help guys!
Old 18th September 2012, 12:33 AM   #12
Minion is offline Minion  Canada
The KTC3228 is the KEC version of the 2SC3228 ...... no two companies would name thier transistors the same unless they were the same ......
Old 18th September 2012, 12:54 AM   #13
I understand. In my search I came upon 2sc3228 which I thought to be the same component I needed. But when in fact it is KTC3228 that I have. When I search that data sheet it brings up the same shape trandistor I have. But I have found some with 2sc prefix and KEC shape. So I am confused a bit. But I am in talks with a couple people in locating what I need.
Again I am new to this so please understamd.
Old 18th September 2012, 01:41 AM   #14
I understand what you are saying but what im trying to get across is that internally a KTC3228 and a 2sc3228 are the same and have the exact same specs for the most part ...... They are the same transistor internally but have a slightly different package .....
Much like when you go to shell and get gas it is the same gas you would get from chevron , or buying a mufler from Mopar or from GM , They are pretty much the same product in a different package .......
You could theoreticly use any transistor with a simular voltage and HFE rating and the curcuit would work .......
Old 18th September 2012, 12:49 PM   #15
I see. Alright thank you.
Help locating C3228 transistor...Hide this!Advertise here!
Need help locating transformer c12mech Power Supplies 7 22nd April 2012 04:50 PM
I'm searching for a specific transistor need help locating chipper Parts 2 8th February 2010 07:04 AM
Locating transistors Canefire Solid State 10 29th December 2006 02:30 PM
Need Help Locating a Schematic! schwarcw Digital Source 3 16th November 2006 07:23 AM
Help locating some parts. Destroyer OS Parts 11 6th May 2006 06:39 PM
