| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
ok, i have 1 question on power supply capacitors and that is on the required voltage for use. i have a 48Vct transformer that i plan to use, i was planning on useing 50V rated caps with the transformer (48Vct, 7A). will this work or will i need to move to a larger voltage rating. i will also have a noise filter before the amplifer. i will test that.
in any case any help would as always be appreciated.
if only it could be used for good, not evil... |
#2 |
Will you be using the CT, as a +/- power supply? If so, then yes; each pole will have only 33V across it.
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
#3 |
ok, thanks. it will be used as mentioned above. ok, i was just wondering if there was some kind of de-rating that was used.
#4 |
If the transformer is 48 VCT then the nominal AC voltage on each side will be 24 volts. Multiply that by the square root of 2 (1.414) and you get 33.9 volts. The voltage may be lower when the transformer is loaded but unloaded with a voltage surge (assume a voltage surge of 10% or more for derating purposes) and now you're looking at ~ 40 volts. A 50 volt capacitor (per rail) would be perfect for that situation.
Mark |
| PC Power Supply Mod - Quick question for someone with an EE etc. | calee4nyaboy | Parts | 7 | 31st December 2009 06:10 PM |
| big caps power supply? | lanchile07 | Chip Amps | 28 | 5th December 2007 10:19 PM |
| Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? | rhythmdiy | Chip Amps | 9 | 23rd October 2007 01:30 AM |
| Just a quick power supply capacitance question | markiemrboo | Chip Amps | 137 | 14th February 2007 05:53 PM |
| Quick TT power supply | scott wurcer | Analogue Source | 2 | 11th February 2004 11:49 AM |
| Page generated in 0.07089 seconds (70.47% PHP - 29.53% MySQL) with 10 queries |
