5.5mm barrel jack & plug - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 7th September 2012, 11:01 AM   #1
jan.didden's Avatar
Default 5.5mm barrel jack & plug
Hi guys and gals,
I'm working on a power amp design to be fed by one of those standard laptop supplies.
I noticed that those supplies have connectors specced like outer diameter 5.5mm and inner diameter 2.5mm. The corresponding panel mount jack then should have a hole with inner dia 5.5mm and center pin 2.5mm. Or so I thought.
But the panel mount jacks I find have an inner pin like 2.35mm diameter, I can't find anything with 2.5mm inner pin.
Is that normal, is there a smaller dia pin to improve mating and contact (the inner pin is normally slotted and the two halves spread out a bit)?
So, am I OK with a 2.35mm pin for a 2.5mm connector?
jan didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 7th September 2012, 11:11 AM   #2
I can't get in deep enough to measure the PIN diameter of my 5.5mm power socket.
The 5.5mm power plug takes a 2mm drill and is a very slack fit.
I don't have a 2.35mm drill to check that fit.
A 2.5mm drill will not fit.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 7th September 2012, 10:43 PM   #3
Enzo is offline Enzo  United States
There needs to be at least a small amount of slack space or the thing won;t always fit. The side contact in the jack is springy and pushed the barrel to the side so one side of the pin will be pressed against the inner wall of the hole.
3.5mm jack replacement problems, help? fanapathy Everything Else 5 23rd July 2012 12:17 PM
(DIY) 3.5mm jack adapter to 2.5mm output Rui Luis Instruments and Amps 4 6th September 2011 06:50 AM
Thinn high quality Audio cable wanted for Stereo Jack plug, 3.5mm tiefbassuebertr Analogue Source 8 27th December 2010 09:04 PM
WTB: 2.5mm plug to 3.5mm plug cable Relax Swap Meet 5 10th February 2007 12:13 AM
RCA Jack/Plug Selection/Switches Pre-amp & 3875 Premium kit Destroyer OS Chip Amps 15 22nd August 2006 06:43 PM
Copyright 1999-2017 diyAudio
