Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th October 2003, 11:35 PM   #61
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Originally posted by Bernhard
What does it help to have the most sophisticated parts on the playback side, if the signal is already spoiled on the recording side by magnetic resistors , cheap op amps and electrolytic coupling caps
If you don't want to have the exactly the same sound they have in recording studio (magnetic resistors , cheap op amps and electrolytic coupling caps ) , you use better components and they add slightly better flavour, because nothing is really neutral. It doesn't matter what they use to make a recording. At home, your equipment will always have a sound of its own and you tailor it to your taste. It's just that better recordings will sound better
If you don't care much, you use "magnetic resistors , cheap op amps and electrolytic coupling caps " at home too. If your taste is more refined, you might use "teflon insulated pure silver wire, silvermica caps, pure gold relais contacts and so on.."
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 30th October 2003, 11:44 PM   #62
btw, aren't you worried about skin effect on these resistors? i mean people get all worked up about skin effect on wire killing their highs and this seems to be a lot of wire.
if only it could be used for good, not evil...
Old 30th October 2003, 11:52 PM   #63
diyAudio Senior Member
fdegrove's Avatar
Default DER TONMEISTER...
Hmmm....Soundengineers???
Aren't those the people that went to school for years in a row so they'd learn to think up every conceivable way to mess up a nice sounding recording?
It seems some do but then you won't actually buy those recordings, or would you?
Cheer up Bernhard, there are more well recorded records out there than you'll ever be able to afford, regardless of your taste in music.
Errr...great post Peter, LOL.
Frank
non inductive resistors in London pointy Multi-Way 0 9th July 2009 11:20 PM
Non-inductive resistors cathode_ray Multi-Way 5 27th August 2008 11:20 PM
Inductive resistors for source resistors bbakota2000 Pass Labs 12 25th March 2005 12:33 PM
wirewound non-inductive 1% resistors GAK Multi-Way 18 18th September 2003 05:26 PM
Non-Inductive Resistors rborer Solid State 9 3rd September 2001 10:47 PM
Page generated in 0.07859 seconds (74.50% PHP - 25.50% MySQL) with 11 queries
