| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#41 |
Interesting. I'll try again one day
#42 | |||
If you can get silver "right" in your system it's a whole new ballgame. This is winding one of a 1.8 ohm resistor. This shows the second wire removed and clear lacquer applied. It's not as perfect as I hoped but it is a lot better than the last winding method. The second layer will go in the voids between the winds.
My "cult-like" following is accepting applications. |
#43 | |
I heard this also and I couldn't wait to do whatever it took to get more. Such is the road I'm on...every step is another joy to behold.
#44 |
It occurs to me that a lathe set on low speed w/ one of these spindles would make an ideal winding machine. Either hand-feed the wire slowly and carefully along its length or find some way to regulate moving the wire along, either way, you'll wind the whole thing in under a minute. (This is assuming you drop the 'between the wire' placement thing, but I don't understand why it's used).
Are you sure there's no shorts in the above spindle? A short, if I understand the principle correctly, would both lower the resistance very slightly and increase the inductance by making the direction the magnetic field is being pushed nonsymmetric. Without an LC meter or a very, very sensitive ohmeter, you wouldn't necessarily know it, either. |
#45 | |
If the brightness is due to more of the signal getting through, then how can you adjust for it except by letting less of the signal get through? And if you let less of the signal get through, then you're right back where you started, no? se |
#46 | |
Adjust the level of the tweeter with a slightly larger silver resistor to reduce it's total output. As a side note if you remove the distortion in the upper frequencies from the rest of the system you may end up prefering a slightly brighter high end.
#47 | |
diyAudio Senior Member
I'll tell you what happens though, it let's you hear what's wrong with the system. Most people find CD too bright for their liking (some are) and (un)consciously try to compensate for it. Maybe they should visit a recording studio or listen to a mastertape first? With silver wire, the more you use it throughout the chain the more you'll like it. Often it's like hearing recordings as they really sound for the first time, quite like the mastertape. Cheers,
Frank |
#48 | |
But how is the noise floor reduced by silver? At least in this context where you're using it to create a resistor. All else being equal, silver is a bit more conductive than copper so for a given gauge and length of wire, silver will have a lower noise floor by virtue of its lower resistance. But in this case, you're using the silver to create a resistor which I assume will be the same value as any other resistor you'd use and since silver is more conductive than say copper, you'd have to use a greater length to get the same resistance and if your silver resistor has the same resistance, it will have the same noise as if you'd made the same resistor out of copper. So where is the noise floor being reduced? se |
#49 | |
Whether someone prefers the sound of a silver wire resistor over an equivalent copper wire one I can understand completely but noise floor hasn't got anything to do with it... Ciao,
Frank |
#50 | ||||
![]() Quote:
And of course unless you listened to a master tape of a recording you already have, how could any meaningful comparison be made? Quote:
Therefore it seems to me that it just boils down to which filters one prefers. se |
| non inductive resistors in London | pointy | Multi-Way | 0 | 9th July 2009 11:20 PM |
| Non-inductive resistors | cathode_ray | Multi-Way | 5 | 27th August 2008 11:20 PM |
| Inductive resistors for source resistors | bbakota2000 | Pass Labs | 12 | 25th March 2005 12:33 PM |
| wirewound non-inductive 1% resistors | GAK | Multi-Way | 18 | 18th September 2003 05:26 PM |
| Non-Inductive Resistors | rborer | Solid State | 9 | 3rd September 2001 10:47 PM |
| Page generated in 0.13008 seconds (90.29% PHP - 9.71% MySQL) with 11 queries |
