Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
DIY silver non inductive ww resistors
Old 24th October 2003, 08:26 PM   #1
tom1356 is offline tom1356  United States
Default DIY silver non inductive ww resistors
I want to smack myself.
These are .8 ohms and go in the midrange crossover.
I really want to smack myself.
I have been putting these off for a very long time because I did not want to buy insulated silver wire.
I don't know why but I havn't been able to bring myself to pay insulated wire prices.
My guess is, it is the unsurity of how much wire do I need? Could I wind them myself? What if there was no improvement?
So I put it off.
They are not pretty.
I don't care.
I could try to wipe the smile off my face but it would be difficult.
I need a smack.
My "cult-like" following is accepting applications.
Old 24th October 2003, 08:38 PM   #2
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Uh... so why do you make a *resistor* out of something that doesn't happen to be very resistive?
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 24th October 2003, 08:56 PM   #3
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
They look like inductors to me... how could they be non-inductive?
Brian
Old 24th October 2003, 09:05 PM   #4
Tim
Because silver sounds better than anything else.
Brian
They are bifilar wound in two layers.
Old 25th October 2003, 02:04 AM   #5
randytsuch is offline randytsuch
Curious how much wire it took to make one, and how much one of those ended up costing?
By bifilar, I am guessing you mean you wound 1/2 the resistor in one direction, and the other 1/2 in the other direction?
Randy
Old 25th October 2003, 03:05 AM   #6
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
By using more of it?
Frank
Old 25th October 2003, 03:09 AM   #7
Squalish is offline Squalish  United States
A) Has it ever been empirically(or even popularly) proven that silver sounds better? I've seen lots of people claiming it's too bright for them to use in their systems for ICs.
B) How much resistance do you get per length?
C) Are you worrying at all about excess capacitance caused by doing this?
Old 25th October 2003, 03:18 AM   #8
fdegrove's Avatar
If you decide to use silver, use it throughout.
For reasons beyond me that works.
8% less than the equivalent copper wire and 35% better sound.
It's meant for low impedance service so capacitance shouldn't be a major concern.
Frank
Old 25th October 2003, 03:30 AM   #9
Randy
They each use about 26 feet of 36ga fine silver wire.
The first winding is 1.6 ohm. The second winding is 1.6 ohm and is wound the oposite way. When tied together the give .8 ohms resistance .
At my house silver sounds better.
I can't measure the capacitance it is too low.
I just made some copper ones 7.2 ohms.
I can't wait to try them.
Old 25th October 2003, 04:12 AM   #10
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Ah, but does two dozen feet of silver necessarily sound better than two inches of something else? Less is more, yes?
Good luck with 'em!
I just got these today. They're 32 ohm 5 watters I had custom made "nude" and using a 55% copper alloy instead of the typical nichrome. They're for a headphone amp though, not loudspeakers.
se
DIY silver non inductive ww resistorsHide this!Advertise here!
non inductive resistors in London pointy Multi-Way 0 9th July 2009 11:20 PM
Non-inductive resistors cathode_ray Multi-Way 5 27th August 2008 11:20 PM
Inductive resistors for source resistors bbakota2000 Pass Labs 12 25th March 2005 12:33 PM
wirewound non-inductive 1% resistors GAK Multi-Way 18 18th September 2003 05:26 PM
Non-Inductive Resistors rborer Solid State 9 3rd September 2001 10:47 PM
Copyright ©1999-2017 diyAudio
