Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Ne5532 Op Amp real world max voltage?
Old 23rd October 2003, 06:32 PM   #21
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
OK, no problem. So unregulated you have +/- 22 V ( still no value of the transformer though ) under load. LM7818/7918 can be used then if they only need to feed the 2 or 4 opamps of the filter.
They need around 3 V over them to function properly so only 1 V is left for ripple etc. Make sure the caps directly after the diode-bridge are big enough. Although 2 x 1000 uF/35 V will do 2 x 2200 uF/35 V might be a more audiophilic approach. Mmm, 4 x 1000 uF/35 V is even more audiophilic for what its worth.
If the supply feeds more circuits LM7815/7915 is a better choice as higher ripple will give too tight values for using LM7818/7918.
It's only audio. Member of the non modular PCB design committee
Ne5532 Op Amp real world max voltage?Hide this!Advertise here!
PCM1794 vs. PCM1798 in the real world? niles Digital Line Level 12 12th December 2016 01:37 PM
TDA7052A - power, & (real world) heat levels ...Sanity Check sought! HankMcSpank Chip Amps 8 11th August 2009 12:17 PM
What about NE5532? rhavecilla Chip Amps 12 6th September 2007 03:05 PM
How well does noise measurement in spice match real world? sonnya Solid State 3 10th November 2003 07:45 PM
