Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Need help with coils in serial connection
Old 23rd August 2012, 03:34 PM   #1
vcanzi01 is offline vcanzi01  Croatia
Default Need help with coils in serial connection
Hello,
I'm interested if anyone knows is there a difference in sound in a serial connection of two coils (Mundorf CFC14 0,22uH + Mundorf CFC14 0,10uH) compared to one of larger value (Mundorf CFC14 0,32uH).
Thanks.
Old 23rd August 2012, 06:56 PM   #2
Andersonix is offline Andersonix  Sweden
Andersonix's Avatar
DCR of two coils in series will not be the same as one coil.
Old 23rd August 2012, 10:07 PM   #3
bear is offline bear
expert in tautology
bear's Avatar
perhaps no difference.
The DCR will be the sum of the two coils vs the DCR of the greater number of turns for the larger coil. Might be identical. Turns is turns. The specs may be published. Either way a trivial difference compared to bumping up to a fatter wire gauge.
What may make a difference is mutual coupling between the two coils depending on how you lay it out. But if they are in the same axis, or some distance apart there should be nil difference. Having them inadvertently in opposition will reduce the inductance.
I wouldn't waste any time or effort worrying about it.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 24th August 2012, 11:45 AM   #4
Thank you.
Old 24th August 2012, 09:07 PM   #5
Andersonix's Avatar
You can look at f.ex. this Madisound table and see that the DCR for two smaller coils in series do not add up to the DCR of one larger coil. Turns ain't always turns....
If you mount the two smaller coils so that they mutually couple, then the total inductance will be larger than their individual values.
Old 24th August 2012, 09:21 PM   #6
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Can you point out on that table where you come to that conclusion?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 24th August 2012, 09:32 PM   #7
R.I.P.
Originally Posted by vcanzi01 View Post
Hello,
Thanks.
There should be no difference, but if the 0.1 is not ~
half the size of the 0.22 you are wasting money.
rgds, sretern.
Old 24th August 2012, 10:11 PM   #8
The thing is that I bought 4 pcs of CFC14/0,22uH and now i need for my other project values of 0,32uH.
If i can connect them in series 0,22+0,10=0,32uH and without loosing sound quality i will do it. The RDC of 0,10uH is 0,07Ohm, 0,22uH is 0,11Ohm.
Old 25th August 2012, 03:20 AM   #9
Andersonix's Avatar
Take f.ex. 0.1mH (0.10R) + 0.2mH(0.14R) = 0.3mH(0.16R)
The DCR of the two smaller coils added (without regard for coupling effects) is 0.24R, so a bit larger than 0.16R of the single larger coil.
File Type: png Screen Shot 2012-08-24 at 20.10.31 .png (30.9 KB, 57 views)
Old 25th August 2012, 11:29 AM   #10
Did it Himself
OK I see what you are saying now, misunderstood what you were saying. Yes, individual coils will have more wire on them compared to a single coil of the same total inductance.
Need help with coils in serial connectionHide this!Advertise here!
Serial Communication with TOSLINK sakibnaz Digital Line Level 3 2nd March 2012 06:30 AM
Serial or parallel K-amps Solid State 19 12th November 2006 01:58 PM
use serial data A'af Digital Source 2 16th January 2002 07:50 PM
