Connex Switches
Has anyone had any experience with the Connex switches from the Parts Connexion? I'm looking at buying their 4x24 switch to build an attenuator, and and their 4 pole six position switch to use as a source selector.
They seem cheap as chips when compared to the other options offered, and with the exception of the Electroswitch I can't afford the more expensive options for the attenuator right now. Why is there such a large price difference, and is their anything that I should be concerned with if I go with this option? How are the others better? The alternative would be to go with an alps blue or noble volume pot for now, and then to save up for something like a Shallco or Elma down the road. If necessary, I could stretch for a more expensive source selector right off the bat. Thanks for all of the input! |
hopat: give us part#s and links to make it easy for us to help you! E
Here's a link for the source selector. Part number Connex 75573 i think.
ConneX 2 Deck, 2 Pole/Deck x 6 Position, Silver-Plated, Non-Shorting (BBM) Here's a link for the attenuator switch. Part number Connex 75502 i think. Connex Rotary Switch, 4x24 Thanks for the advice. |
They look like generic Chinese switches. Might be a bit cheaper from ebay, e.g.:
4P 24 Step Rotary switch Attenuator Volume Control DIY | eBay 4Gates 6 Step Rotary Switch Volume Control Selector DIY | eBay Can't say about quality, haven't used mine yet. They're going into one of Richiem's notch filters eventually. I think he used similar switch types in his own unit: Active Twin-T notch filter |
Thanks for the identification EssB. Can anyone comment on the differences between these generic switches and the more expensive Shallco's or Electroswitch's? Do they tend to sound worse, or is the difference one of longevity, or tactile solidity? Would I be better off going with a pot at this price point? I found a link to a similar switch that has more specs.
Audio Catalog Here's the description of the part VR-S24x4G 24k Gold Plated 24 x 4 Excellent Quality and durable Potentiometers!! Operation temperture and relative humidity: -55 to 85 degree C, 93% Maximium Working Voltage: 150V Maximium current: 0.3A Contact resistant: lesser than 0.02ohm Insulation resistant: more than 1000Mohm Maximium Voltage 500V Turnning force: 0.2-0.7N.M Turning Angle: 15 degree Recommended for ladder type Stereo setup 4 layers with 24 steps continuous (made before break) switch for volume control. 10mm staft Recommended for Stereo One of the best quality switch potentiometers on very affordable price You need install resistors or transformer for volume control Continuous type (Made before break) Made in China Weight :62 (gram/each) Is there a strong reason to spend more when my non-chassis budget for a passive pre is in the 100-150 dollar range? |
| All times are GMT. The time now is 08:59 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
