Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Non-magnetic latching?
Old 16th August 2012, 05:04 PM   #1
muckrake is offline muckrake  Canada
Question Non-magnetic latching?
I've opened a couple models of small sealed latching relays and the latching mechanism in both had small permanent magnets for retention. Can this possibly affect sound, being quite close to the contacts? Also, does anyone know of latching relays that use spring-based retention? From what I see in datasheets, the type of mechanism isn't normally listed.
Old 16th August 2012, 05:07 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
May be. As some people here believes that the name of brand of a capacitor also affects sound
Oh, put them about 1Km far from output transistors to prevent hall effect in them.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 16th August 2012, 05:19 PM   #3
jcx is offline jcx  United States
possible source of microphonics if conductors move relative to the magnet, or actuated coil for that matter - doesn't have to be latching relay to have a B field
some audiophiles are sure ferromagnetic component leads are audible problems
but others (likely even some of the same audiophiles) rate transformer attenuators, switched by reed relays as the "the ultimate" volume control
there are precision scientific, industrial measurement instruments - including AP audio analyzers that use relays all over
understand your parts, cirucit, design, layout to evaluate, control any issues
Old 16th August 2012, 05:36 PM   #4
Maybe I should rephrase the first part of my question: while the comments indicate than any effect would be miniscule, can someone give an order-of-magnitude estimate of such an effect in dB relative to the signal? For example, if it's < -120 dB then it cannot possibly be audible; if it could be larger than this, then audibility is at least arguable.
Also, I'm still curious if they make spring-latched types.
Old 16th August 2012, 05:57 PM   #5
Forget it. The spike voltage at the coil turn off may be coupled if not properly damped (Diode and cap across the coil). Mechanical noise would be negligible.
Old 17th August 2012, 05:00 AM   #6
gmphadte is offline gmphadte  India
Even if there is a magnet, its magnetic flux path will be through the rotor and will leak negligible flux.
Gajanan Phadte
Old 21st August 2012, 08:27 PM   #7
disco is offline disco  Netherlands
disco's Avatar
To quote Eva:
"Mechanical contacts have been used for ages and over time they are well known to become dirty, oxidized, noisy, coated by a layer of every substance volatilized in the ambient, etc... In the end they produce great amounts of distortion when small signals are involved. For example, relays have a minimum current rating and special ones are required in order to switch small signals. After some aging, the contacts in standard relays and switches have trouble to start conducting when current/voltage is too low. This becomes worse when some DC component is involved due to electrolysis."
jaap
Old 21st August 2012, 09:19 PM   #8
And none of this applies to hermetically sealed relays.
Old 22nd August 2012, 01:10 AM   #9
mickeymoose is offline mickeymoose  Canada
Only to those that were sealed in a vacuum.
Low-level signal relays or switches use bifurcated gold-plated (or other noble materials) contacts. You never use "toggle" or preassure type switches or contacts for low-level signals, allways use self-cleaning (like slide) switches. E
Old 22nd August 2012, 01:38 AM   #10
Sealing in vacuum makes no sense due to the pressure difference. It's much easier to use a non-reactive gas such as argon or helium at slightly below atmospheric pressure (i.e. at max altitude the relays are likely to be used at). This decreases structural requirements of the relay body and seal. Since we're talking about low-level signals, arcing is not an issue.
Non-magnetic latching?Hide this!Advertise here!
Slectable momentary or latching action TheFixer Construction Tips 13 8th September 2011 12:03 AM
Latching Switch Assemblies bishka Parts 9 19th September 2010 07:07 AM
control a latching relay with one switch? peace brainerd Parts 13 8th January 2009 04:24 AM
Driving a latching relay Nixie Parts 5 28th August 2008 07:41 AM
555 timer latching nickch Parts 1 20th July 2005 08:48 AM
Copyright ©1999-2017 diyAudio
