Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Choosing a relay for loudspeaker switching
Old 16th August 2012, 04:32 PM   #21
bear is offline bear
expert in tautology
bear's Avatar
If you are in series with the signal, I strongly suggest multiple contacts.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 16th August 2012, 04:34 PM   #22
expert in tautology
bear's Avatar
Originally Posted by AndrewT View Post
Bear,
how do you get the multi-parallel contacts to open at the same time?
You do not.
Why do you need to do this?
The important aspect is IF the closed state is important to signal transfer then a single contact is a major liability, imo.
_-_-bear
_-_-bear
Old 17th August 2012, 08:44 AM   #23
R.I.P.
The point is that on opening the first to open see no stress. The last of the contacts to open sees the full duty of trying to break the circuit.
regards Andrew T.
Old 30th August 2012, 06:24 AM   #24
ST7677 is offline ST7677  India
It's bad from safety perspective, if it welds. May be we can factor that while selecting individual contact rating.
But isn't it good from long term degradation perspective? Because it's likely that only a single contact will continue to get corroded and the other contact will continue to provide clean signal path to low load?
Old 30th August 2012, 10:20 AM   #25
R.I.P.
You could be right.
Do some long term tests and come back with the results and your methods of getting those results.
regards Andrew T.
Old 4th September 2012, 03:07 AM   #26
expert in tautology
bear's Avatar
If one contact can weld, then you don't have enough contact, imo.
Also the type of the contact shape matters, as does the contact material... crossbar is likely best for audio, IF you could get it...
My thinking is that no matter what the contact being used, more in parallel will provide substantial reductions in terms of the issues inherent in relay contacts. One can assume for the benefit of discussion that we are comparing one "adequate" contact to multiple contacts ("overkill").
I prefer the "overkill" approach, IF the signal is required to flow through the contacts, as opposed to being a path to shunt a signal to ground for turning off the signal path/flow... (that's not the same as providing a path to ground that will enable a circuit to operate).
Just my experience talking here, that and what I have read in passing.
_-_-bear
_-_-bear
Choosing a relay for loudspeaker switchingHide this!Advertise here!
Switching loudspeaker with relay quietdragon Solid State 8 3rd November 2011 04:46 AM
Inrush current limiter and choosing a correct relay Legis Power Supplies 5 30th September 2011 06:41 AM
need dpdt switching relay help subaruzero Parts 1 27th September 2006 07:27 PM
Relay switching circuit please jnewbold Solid State 10 3rd March 2005 06:39 AM
AV amp switching relay TPC Solid State 1 20th April 2003 05:00 PM
