Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Is 2SK 246GR2 the same as 2SK246GR TPE2
Old 3rd August 2012, 12:51 PM   #1
pshdk is offline pshdk  Denmark
Default Is 2SK 246GR2 the same as 2SK246GR TPE2
I am looking for the 2SK246-GR2 transistor and have found a 2SK246-GRTPE2.
Can I use the 2SK246GR TPE2 in place of the 2SK246-GR2?
Thanks,
Paul
Old 3rd August 2012, 01:32 PM   #2
Lazybutt is offline Lazybutt  France
Where did you find these references??
What matters is they are GR (green) which defines the Idss range. The rest is (i suppose) manufacturing codes, and is unimportant to the device specs
Look at a datasheet to understand
Old 3rd August 2012, 03:33 PM   #3
Single FETs used for current sources: 2SK246GR2 ( three per channel)
Sony n80es
Old 8th August 2012, 12:25 AM   #4
ticknpop is offline ticknpop  Canada
Maybe Sony had a narrower GR IDSS range pre-selected by the manufacturer so they would not require production selection or potentiometer tweeking on the line and the manufacturer labeled them that way to indicate the narrower IDSS range.
Is 2SK 246GR2 the same as 2SK246GR TPE2Hide this!Advertise here!
Replacing 2SK 215/2SJ78 palesha Solid State 4 9th June 2013 05:33 AM
Wanted 2SK 3313 KCC Swap Meet 0 13th May 2009 02:13 AM
Aleph 5 with other FETs ??? 2SK series Adrie Pass Labs 2 24th January 2005 08:44 AM
2sk 135 & 2sj 50 janey Swap Meet 10 6th February 2004 10:43 PM
Transistor info (2SK,2SJ...) Voyager92 Solid State 1 17th April 2003 03:08 PM
Copyright ©1999-2017 diyAudio
