Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
output device technology as of 2012
Old 4th August 2012, 03:33 PM   #11
5th element is offline 5th element  United Kingdom
5th element's Avatar
Originally Posted by fpitas View Post
It's a lot tougher to get surface mount devices hooked to a heat sink.
Usually surface mount devices that require a sink come with exposed metal pads to facilitate the easy coupling of a heatsink too them. Having said that, most SMD devices that need heatsinking generally only require a specific exposed tab/pin to be soldered to the PCB, so that a copper plane can dissipate the heat.
Then, for really high power stuff you use normal through hole parts as the devices need to be large enough anyway, to be capable of transferring the heat the produce to somewhere else.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 4th August 2012, 03:41 PM   #12
fpitas is offline fpitas  United States
I design RF power amps for a living, so I heatsink SMD transistors all the time by designing a hole in the PCB, and clamping the device or using its flanges. Through hole really isn't an option because of package parasitics.
Old 4th August 2012, 03:55 PM   #13
marce is offline marce  United Kingdom
6 layer board, 4oz copper each layer, devices clamped to the case via the PCB, or use active heatsinking with heat pipes. And a thermal camera helps so you can sea the thermal profile of the system easily.
Regarding older devices, I think the area of silicon used for some older devices was bigger than used today, with shrinking SMD devices and the same capacity in smaller more modern packaging, more devices per wafer= more profit.
output device technology as of 2012Hide this!Advertise here!
cascode output stage what device? Stefanoo Pass Labs 24 27th February 2009 03:35 PM
shunt PSU and output device Stefanoo Pass Labs 3 26th November 2008 10:42 PM
Gain Matching Output device ???'s Zero Cool Everything Else 6 10th December 2006 04:56 PM
ccs biased output device davidallancole Solid State 2 26th November 2005 07:33 PM
BJT - how can the output device manage Stormo Solid State 3 3rd February 2003 11:25 AM
