Dual primary transformer help
Could someone tell me the proper way to hook up the transformers primaries for 120v?
http://www.apexjr.com/images/66938_sc7.pdf The secondary is easy but I am not sure what color wires go to the hot, neutral and ground. |
i would connect them in parallel for 120V, so connect 1 and 2, 3 and 4, the 1/2 combination to neutral, 3/4 to hot (but actually that does not make any difference, it's AC anyway). don't know what tha 1A and 4A are for.
1 and 4 are likely for 110/220V, 1A and 4A for 120/240V
That was what I was thinking but I needed some confirmation.
Any problem with connecting 1,1a and 2 and doing the same for 3,4a and 4? |
connect 1 and 3 to mains, measure the secondary voltages, and do the same with 1a and 3. any difference? or measure the resistance between 1 and 3 and 1a and 3.
I would say u should not buy this/use this transformer as the schematic is very vague/wrong.
I'd say 1A and 4A are for a 240V arrangement, 3 and 2 joined. rgds, sreten. |
You can't parallel all three connections for both windings because for some reason they have put the extra part on the opposite ends of the two windings. So for 110V join 1 and 2, and 3 and 4, then use 1/2 for one connection and 3/4 for the other. For 120V join 1A and 2, and 3 and 4A, so the two connections then are 1A/2 and 3/4A. How do I know this? Look for the dots at the end of the winding diagram. |
| All times are GMT. The time now is 06:32 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
