Help me guess heat sink specs - diyAudio
Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th July 2012, 06:35 PM   #1
ChrisA is offline ChrisA  United States
Default Help me guess heat sink specs
Is there a rule of thumb for estimating how well a given heat sink will work in free air. I need to make a rough guess for a pair of heat sinks I found in a pile of salvaged junk.
Each heatsink is a simple 2 x 2 inch "U" channel with small grooves and is 9.5 inches long. about 1/8th inch thick. What makes these nice is they have a socket for to-6 transistors. Here is a photo
https://www.dropbox.com/sh/ujepcbbgevxj75s/OMcwO7YYKT
Yes, I know I could measure then by bonding a dummy load resister to the heat sink and measuring temperature vs current in the resistor. But "what a lot of work" and I'd STILL need to make an initial guess.
Old 31st July 2012, 12:58 AM   #2
Here are a few links that might help you, One of them calculates them by just the surface area,
HEATSINK QUESTION
jer
Old 31st July 2012, 03:55 AM   #3
Thanks, So by several methods it looks like about 20W continuous. But music is not a flat sine wave. Next I'll have to figure out how to set up a VI limiter to get the most possible use of this heat sink.
Old 31st July 2012, 04:02 AM   #4
That is about what I guessed 10 to 20 watts or so.
You'd be surprised what a small fan would do.
Maybe closer to 40 or 50 watts but at around 80 degrees celsius though.
jer
Heat Sink Heat Sink Sources for Pass Amplifiers manmohan singh Pass Labs 9 17th March 2012 12:37 AM
heat sink khimh Subwoofers 1 8th December 2011 01:50 AM
Is this heat sink OK? portreathbeach Chip Amps 5 28th February 2010 12:56 PM
How much heat sink is necessary? rosss Pass Labs 11 23rd February 2003 06:23 AM
Copyright 1999-2017 diyAudio
