| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
need ZTX499 transistor or EQ
any suggestion |
#2 |
Are you sure 499 is correct? I can't find any current or obsolete listing for that part.
ZTX449? |
#3 |
Yes i'm correct it's use in an anthem pre2
#4 |
Can you get a photograph of the part? I will see what I can find out.
#5 |
#6 |
http://www.google.com/url?sa=t&rct=j...iJhDyw&cad=rja
Digikey link: http://www.digikey.co.uk/product-det...TX449-ND/92532 Last edited by frank1; 31st July 2012 at 03:18 PM. |
#7 |
As frank suggested, that is indeed ZTX449.
They are still available. |
#8 |
Hi everybody thanks..
now i still have an problem, all Anthem Pre's has hum een when the volume is zero. you still hearing hum on the background. i hate hum. there is nothing wrong i have three whit the same problems does anyone has an solution for this problem, or is the best way to sell and buy a other one |
#9 |
sub in a BC550 and see if it fixes it,I have interchanged them before with no problems in a F5,
Good luck! NS |
| Available EQ on combined electronic crossovers/ EQ: Berhinger, dbx, etc | rick57 | Digital Source | 2 | 10th May 2011 02:09 PM |
| Can I build up these Darlington transistor if I use two BJT transistor ? | gaborbela | Parts | 9 | 15th July 2010 06:30 PM |
| Can bias transistor mount on top(body) of output transistor?? | Leolabs | Solid State | 23 | 16th February 2008 12:35 AM |
| Passive EQ to active EQ | Nuuk | Multi-Way | 13 | 24th May 2004 07:59 AM |
| Available EQ on combined electronic crossovers/ EQ: Berhinger, dbx, etc | rick57 | Multi-Way | 10 | 11th June 2003 10:59 PM |
